Replacing headlight motor?
Old Feb 13, 2003 | 07:53 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
My headlights are now staying up when I turn them off. I can manualy trun them down, and when I turn them on they go up again but not back down. so would this mean I have to replace the motor? thanks fo any info. Tim
Old Feb 13, 2003 | 08:22 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
Tim,
That sounds more like a relay problem to me.
Jeff
Old Feb 13, 2003 | 09:05 PM
patrickm00's Avatar
do they make a clicking noise and run longer than they have to to go up? if so, then get the rebuild kits. actually, for the $10 and 2 hours of work, you might want to just try the rebuild anyway, it can't hurt.
and when you do it, use LOTS of liquid wrench and give it plenty of time to soak into the screws. 6 of the 8 in mine snapped off, and i spent more time drilling and tapping holes than anything else.
Old Feb 13, 2003 | 10:35 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
I hear a clicking sound when i hit the switch but they come up like normal. where do you buy the rebuilt kit from the dealer? Thanks
Old Feb 13, 2003 | 11:14 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
If they go up fine but don't want to go down it sounds more like a cut wire some where than a broked motor. Expecally if both are doing it.
Old Feb 13, 2003 | 11:16 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
mine do that sometimes... but mine is a problem with the switch going bad... i have to make sure i push the switch and hold it down until they go all the way down... if i don't they will go down as only as far as they have gone before i pull my finger off...
Old Feb 14, 2003 | 02:54 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
Well heres the story leading to this once in a while they would stay up and I would just reflick the switch and they would go down and some times they would go down on there own after 10 to 20 min. now there up
Old Feb 15, 2003 | 07:10 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
replace the switch.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Leggman1
Aug 6, 2015 04:15 AM
