Won't Start Need Help!!!
Old Feb 15, 2003 | 02:08 PM
zr1 32 16 405's Avatar
i took my heads off to have them replace the valve guides and do the basic valve job, drilled exhaust guides, and spring shims. I followed the book exactly and i labeled everything. I had to cut the passenger side ground that connects to the head along with the AIR cat tube. the bolt was impossible to get off. So when everything came back i put the heads back on connected the battery ground and the driver side head ground. the other ground is not connected. Every wire is back in place except that one ground, i go to start my engine for timing but it won't turn over at all, the soleniod doesn't click or anything. I though it was that main ground wire that would prevent it but its to weak, the starter should atleast turn over. what should i try before towing it to the shop.
Old Feb 15, 2003 | 08:10 PM
kevinc's Avatar
Car: 1982 Z28
Well, uh, I'd start by reconnecting that other ground and retesting...
Old Feb 15, 2003 | 09:16 PM
yea i need to connect it
Old Feb 16, 2003 | 07:56 AM
ede's Avatar
ede
battery dead? rockers adjusted and timing right, or close to right? power to the starter? have you tried trouble shooting it? checked anything?
Old Feb 16, 2003 | 12:49 PM
the valves are timed correctly, battery is good and i going to check power to the starter. is there a fuse or fusable link to the starter?
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
