pontiac lovers inside
Old Feb 15, 2003 | 05:02 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok my friend just found a 428
he bought it for about 100 bucks
how good are the motors and what kind of issues do they have?
what would you guys recomend as a decent build up on it using the 6x heads... unless you know where he can pick up some 16 heads
Old Feb 15, 2003 | 06:27 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Are the heads 6x-4 or 6x-8? Just rebuild the heads with big springs or get the edelbrocks. And through on a XE274 or so cam, should make tons-o-torque=tons-o-fun!
Old Feb 15, 2003 | 06:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems like the last year of the 428 was about 62 or 63.... I recall it being an option on the 59 Catalina I had....
I don't even know for sure if the later-model heads would bolt up to it. I do know, from one occasion when I was building a 64 Pontiac, that they changed several things about the crank flange when they went from the old 4-speed HydraMatic transmissions to the T-400 in 65.
Sounds to me like an opportunity for lots of research. I don't think there's any real easy answers on that one.
Old Feb 15, 2003 | 06:38 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
no heads on the block so he is going ot have to buy them
he wants the 16's but doesn't think he could find any for a good price
and the 6x heads if he did find those not sure as to which one he woudl get be it 6x-8 or 6x-4
he thinks the 4's would raise compression up to high and the 8's would lower it too much
how much are the edelbrocks?
Old Feb 15, 2003 | 09:29 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
EDIT: THIS IS NOT RX7SPEED. MUCHWHITESMOKE HERE, JUST ACCIDENTALLY GOT ON WITH HIS USERNAME...... AGAIN!
nah, the 428 was from like 66-69 when the 455 came about the 428 was obsolete. so it can take all the "present" day poncho stuff.
in 64 you may be thinking of a 389.
other than that i dunno. poncho parts are hard to come by as idaho is kind of a black hole as far as parts and availability. that's why i wanted to try the 6X's if the 16s didn't pan out. since 6x4s are harder to come by i will most likely be looking at 6x8s.
Old Feb 15, 2003 | 10:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
The edelbrocks cost $1679. The 6X heads are flow better then the 16's, infact they are one of the better flowing stock heads.
Old Feb 16, 2003 | 02:37 PM
muchwhitesmoke's Avatar
Car: for now i have a 79 firebird that had a toasted 301 (imagine that!)
Engine: well i *had* a 301, but there is a pontiac 350 on the stand to get me on the road again and a 428 after that :D
Transmission: th350
oh, wel i got some flowbench info from the big bad net and plugged it into my d dyno, and the 16s seem to do a lot better. then again this is info from the net, nowhere does it say that these tests were done on the same flow bench and am using the d dyno, so i have several variables, but it makes a HUGE difference on the ddyno, so i'm at a loss.
Old Feb 16, 2003 | 02:44 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Old Feb 16, 2003 | 02:58 PM
Transmission: th350
here AGAIN !!!!!!!!!!!!!!!!!!!!!!! that was me that meant to make that last post. seems like everytime i get on here i get rx's da<x>mn username and password.
Old Feb 16, 2003 | 08:18 PM
Vader's Avatar
Are you boys sharing an ISP?
Old Feb 16, 2003 | 08:38 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
There sharing a domicile!
Old Feb 16, 2003 | 08:39 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
There sharing a domicile!:lala:
Old Feb 17, 2003 | 09:58 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hey matt quit using my name
Old Feb 17, 2003 | 11:55 AM
Vader's Avatar
Do you mean you could say naughty things like "pooh-pooh" and "wee-wee" and we'd have to blame Wankel Dude? COOL!
Are you guys both using the same ISP, like Amatuers On Line or CompuSuck, or something?
Old Feb 17, 2003 | 01:40 PM
rezinn's Avatar
Using the same ISP makes no difference. They must be using the same computer to stay logged in to one name or another.
P.S. If I ever say "pooh-pooh" or "wee-wee," it was Vader playing around on my name again.
Old Feb 17, 2003 | 05:06 PM
Transmission: th350
i can now that i got the rx7speed virus out of my computer.
yes, we were using the same comp. he was staying at my house for a while. dam<x>n thing has been corrupted and infected ever since
Twin_Turbo
Mar 14, 2016 10:10 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
funkyTA
Sep 10, 2015 06:38 PM
