question about turning engine over by hand
Old Feb 16, 2003 | 05:28 PM
mauibluebird's Avatar
When I crank my engine over by hand with a socket on the crank bolt do I go clockwise or counterclockwise?
Old Feb 16, 2003 | 06:01 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
counter clockwise..
Old Feb 16, 2003 | 06:04 PM
Scott C's Avatar
Clockwise as you are looking at the front of the engine...
Old Feb 16, 2003 | 08:29 PM
Ok, so i turn it clockwise or right as if I was tightening the bolt? Everyone agree? Will I break something if I go the wrong way?
Old Feb 16, 2003 | 08:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You will only loosen the bolt if you go the wrong way.
You will only break the bolt if you go the right way.
Don't use the bolt. Take the bolt out, remove the balancer, and use a crank socket. I'd hate for you to be the next person making the familiar "ARGHHH! My crank bolt broke off!!! (or stripped)" post.
Old Feb 16, 2003 | 10:17 PM
Scott C's Avatar
Bahhh...Use the crank bolt, but only if you remove all of the spark plugs!! Much less resistance that way
Old Feb 17, 2003 | 04:42 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Old Feb 17, 2003 | 09:45 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I agree...don't use the bolt. My friend broke one off in his crank trying to do that and it sucked! I'd get one of these if you don't wanna remove your balancer to rotate your motor without breaking the bolt.
That's summit racing part# pro-66782, engine rotation adapter. It bolts to the balancer after you remove the crank pulley.
Old Feb 17, 2003 | 10:57 AM
Vader's Avatar
If you're not going to do a lot of hand positioning of the crank and/or don't want to remove the balancer, use a strap wrench on the crank sheave.
Old Feb 17, 2003 | 11:48 AM
dans82bird's Avatar
Engine: 302
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
