Stupid question but what way does the engine rotate
Old Feb 17, 2003 | 06:53 PM
Duke901's Avatar
Car: 89 Formula
I found a marine 305 to put in my moms 83 camaro, but it says it rotates ( LH ) . Is that the same way the normal SBC rotates. The motor is rated at 200HP with a 2 barrel, and max rpm is 4200 to 4600. I can get it very very cheap. If the motor does rotate the same way it will be alot better then whats in the car now. It has a 1978 305 with a 2 barrel rated at 145HP with unknown mileage.
THANKS
Old Feb 17, 2003 | 06:54 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Clockwise, as viewed from the front.
Pete
Old Feb 17, 2003 | 07:00 PM
Duke901's Avatar
Car: 89 Formula
So does that mean the marine 305 wont work.
Old Feb 17, 2003 | 07:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
they ALL rotate the same way.
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
LH is standard rotation and RH is reverse rotation. Your ok.
Old Feb 17, 2003 | 07:41 PM
No4NJunk's Avatar
Dead wrong!!
Go here!!
Or here for the RH 305
Old Feb 17, 2003 | 07:44 PM
Duke901's Avatar
Car: 89 Formula
Ok thank you, so LH is standard like every other chevy and will be ok to put in the car. Also sense it is a marine motor what is the difference between a normal motor, is it a stronger bottom end or more aggressive cam or what.
THANKS
P.S could that motor be one that is standard rotation but has the cam going in the opposite direction.
Old Feb 17, 2003 | 08:04 PM
No4NJunk's Avatar
Nothing really. Maybe cam specs will be a little different but nothing out of the ordinary. Those motors like a lot of horsepower. As far as the bottom end....not really sure if they built it or not. All the motors are different. Just depends what the guy wanted in it. The application is pretty much the same.
Old Feb 17, 2003 | 08:08 PM
No4NJunk's Avatar
No. The crank, cam and distributor all have to be changed in a RH engine. You are fine. The motor you have will rotate the right direction.
Old Feb 17, 2003 | 08:10 PM
Duke901's Avatar
Car: 89 Formula
OK thank you very much.
Old Feb 17, 2003 | 08:32 PM
wyldbillracer's Avatar
Duke901: you may want to install a new cam, reason being that marine engines are built to live at 4500 to 5000 rpm, with hp being more inportant than torque, your car will live most of its life(unless it stays on a race track) around 1200 to 2500 rpm, if you pull a marine 305 from a boat and put it in your car it will have great top end power but not as much torque as an automotive 305. Along the same line, I have a marine 350 with an automotive cam, and have 100,000+ miles of hard pulling and have had no trouble, as far as internals, the bearings are the only real diff between an automotive and marine engine. Also the freeze plugs should be brass on a marine engine. hope this helps
Old Feb 17, 2003 | 08:43 PM
Duke901's Avatar
Car: 89 Formula
What kind of compression do marine engines usually have.
Old Feb 17, 2003 | 11:58 PM
should be about the same as an automotive engine
Old Feb 18, 2003 | 05:00 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Cam, dist - OK, but why the crankshaft??
Old Feb 18, 2003 | 05:19 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
pretty sure it's the oil passages that are different
Old Feb 18, 2003 | 05:26 PM
z_power's Avatar
Car: '89 GTA
yep, they aren't symmetric - didn't notice it before, thanks!
Old Dec 4, 2023 | 09:14 PM
poppy 48's Avatar
Re: Stupid question but what way does the engine rotate
Pete
Some older boats that had twin screws had one engine reversed for the cavitation, not sure how they do it now !
Old Dec 4, 2023 | 09:42 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Every member that replied in this thread has died of old age.
Why the F*ck did you did you dig up a 2 decade old thread?
To the people that run this site. Why the F*ck is a Day 1 new member allowed to reply and dig up 2 decade old threads?
Jesus H Christ. WTF
Old Dec 4, 2023 | 09:59 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'd guess he did a Google search for the subject and didn't pay attention to the posting dates?
draco
Nov 19, 2007 10:46 AM
dimebag
Jul 22, 2006 09:22 AM
joshnryandad1
Jan 17, 2006 11:51 AM
Guss_B
Jan 19, 2005 01:48 PM
manchesterbeast
Feb 6, 2004 02:47 PM
