Xr264hr
Old Feb 19, 2003 | 01:39 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Xr264hr
xr264hr 212/218 duration, .487/.495 lift 110 lsa
will comp 981 springs control this cam, if not what will?
Or should i go with the xr258hr 206/212 .480/.487 lift 110 lsa
This will be a daily driven 350, ported 305 heads, 750 cfm carb, performer intake, long tubes bullet mufflers, 700r4 stock stall 3.42 rear.
thanks
Kevin
Old Feb 19, 2003 | 06:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/catalog/056_057.html
Comp recommends 986.... 1.45" outer diameter
I'm running that cam with 1.6 rockers and 987 springs (next step up) in a 305. Runs OK, for a 305.
Old Feb 19, 2003 | 01:13 PM
Engine: 383, L69
http://www.sdpc2000.com/cart.asp?act...2060&pid=81626
What about these springs, they say .550 max lift.
Old Feb 19, 2003 | 01:23 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I run the next size up Comp cam (in sig) & had to go to the 987 springs to cure valve float over 6k. This was as per Comp's techline reps reccomendation.
Old Feb 19, 2003 | 01:28 PM
Engine: 383, L69
well the car is a daily driver and it will never see over 5500 rpms.
Old Feb 19, 2003 | 01:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are inadequate. They're 1.25" diameter. They're not going to control an agressive roller cam.
Believe the cam mfr's recommendations. They will not warranty the cam if used with inferior springs that don't meet their minimum specs, like those GM stock ones. And the engine won't run nearly as strong with valve floaters like those stock springs, as it will with something that has enough nads to do the job right.
Old Feb 19, 2003 | 01:44 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by RB83L69
........as it will with something that has enough nads to do the job right.
Is that an indirect message?
Old Feb 19, 2003 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm not a big fan of stock valve springs..... they're pretty weenie
Catch me sometime right after I've had to deal with yet another broken one, I'll tell you how I really feel.
RWO3
Apr 7, 2013 12:25 AM
iroc2121
Apr 17, 2012 09:15 AM
jtsk
Dec 23, 2010 01:10 PM
91Z28-350
Jun 4, 2005 08:34 PM
gruveb
Dec 6, 2002 08:51 PM
