What air cleaner should I get???
Old Feb 19, 2003 | 05:19 PM
CamaroX84's Avatar
I just bought a Holley double pumper carb (P/N 4778-5), so I can switch my car from TPI to carb. I was wondering what air cleaner assembly will fit this carb (open element, and hood clearance isn't an issue, as I have a cowl hood). Also, am I going to need to do anything special for the throttle linkage? I have an 84 Camaro parts car with all the throttle linkage if that helps. Thanks in advance.
Old Feb 19, 2003 | 05:28 PM
darbleinad's Avatar
Car: 84 Trans Am
do you have an intake for your new holley carb? as for air cleaner...why not a just any old open element air cleaner, like a 14" one, with a 3" or 4" tall K&N filter.
Old Feb 19, 2003 | 05:56 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i used a spector i think that was the name, bracket for my carb . i've got a th350 so i needed one with a kick down bracket, if you've got a 700 you'll needsomething different for yours. any filter with a 5 1/8 holes will fit. a k&n would be your best bet
Old Feb 19, 2003 | 06:10 PM
CamaroX84's Avatar
Yeah, I'm getting an Edelbrock RPM Performer air gap manifold. The stock bracket won't work? Thanks.
Old Feb 19, 2003 | 06:18 PM
craig's Avatar
Car: 86 camaro
my bracket didn't work, i went from a fi v-6 to a carb. the bracket i used is about $12. at autozone
Old Feb 19, 2003 | 06:31 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That intake causes a lot of trouble for hood clearance. Talk to F-Bird'88 and he will steer you to a good Corvette drop base aircleaner assembly that works well with the stuff you want to use
Old Feb 19, 2003 | 07:48 PM
darbleinad's Avatar
Car: 84 Trans Am
normally you would be right, but he said he has a cowl hood, therefore no clearance problems.
Old Feb 19, 2003 | 08:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Personally I like the Moroso open element drop base 'racing' setup. Their words, not mine.
Old Feb 19, 2003 | 11:16 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
www.ramairbox.com
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
