wiper motor without washer?
Old Feb 24, 2003 | 09:06 PM
camaro_1983_383's Avatar
i was wondering if anyone knew of a wiper motor for our cars without the washer. i dont really care for washers, i rarely use it and it leaves a nasty residue. it would help clean up the bay alot!
thanks
Old Feb 24, 2003 | 09:44 PM
Vader's Avatar
At least by 1986 (and possibly before) the impulse (reciprocating) wash pump was replaced with a separate centrifugal pump in the washer reservoir. I'm not sure how the later wiper motor would fit your mountings or linkage, however.
Old Feb 25, 2003 | 12:08 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
couldnt' you just pull the washer bottle and remove the tubing that runs to the bottle itself? I took my washer bottle out last summer to replace it with a brand new one, but I forgot to order a new one and its been sitting in the house ever since. I dont' see why you couldn't just cut the tubing off or something to that effect.
Old Feb 25, 2003 | 11:37 AM
i figured that the motor without washer would be alot smaller. Vader- "at least by 1986" does that mean before or after 1986. i have a 83. thanks
Old Feb 25, 2003 | 12:05 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
after 86.
Old Feb 25, 2003 | 02:33 PM
Vader's Avatar
My '86 TA has the "large" wiper motor, with an integral washer pump. I should have said "1987 MODEL year", since as I recall, the '87 I looked at closely had the separate pump.
Please correct me if my memory is as bad as my golf swing...
Old Feb 25, 2003 | 03:30 PM
Jza's Avatar
Jza
Because just "cutting" or hacking off pieces that you don't want anymore is the main reason so many of these cars are in the sad shape they're in nowadays. I for one am glad to see someone at least attempting to do something the "right" way. Here's to you camaro_1983_383..
Old Feb 25, 2003 | 03:48 PM
nikh23's Avatar
well i didn't mean it in a way that one would just take a hacksaw and start "cutting" away at the tubing. i meant to just detach the tubing from the motor itself, I was unaware of the fact that different motors were avaible for those without washer bottles. sorry
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, my '86 has the integral washer pump, too.
And I've been thru 3 pumps already, and need a 4th. The damn pump runs dry when there's no fluid in the hose. When the pump runs dry, the metal motor shaft burns out the center of the plastic impeller. This leaves you with a motor that spins and spins- but never sucks any washer fluid up.
I've wanted to convert to the remote pump for some time now, but can't find a decent one in the junkyard. Either they're missing, smashed, or dirty as all hell.
Old Feb 25, 2003 | 03:58 PM
right on, i will check it out. thanks for the advice.
Old Feb 27, 2003 | 02:51 PM
Jza's Avatar
Jza
Sorry nikh23, didn't mean to sound harsh or anything. Just obviously dealing with some frustration related to certain kinds of shortcutting (for example the hole-in-the-floor-so-i-can-change-fuel-pumps-easier mod). It's all good.
Old Feb 27, 2003 | 10:36 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
not if its done with a hinge and some dzus fasteners
Old Mar 2, 2003 | 07:31 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
for info: I had problems finding a pump for my 83Z. The parts places kept trying to sell me one that was not "part" of the wiper motor. Finally I noticed many of the little front wheel drive jobs in the junkyard had the same style wiper motor and pump. I got a one off a celebrity (sure about that one) and another one out of a similar sized buick. The particular junkyard I go to usually doesn't even charge for the tiny little parts. Both pumps worked, I installed one and put the other one away for next time.
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
fonzie85
Aug 13, 2015 11:50 AM
slade5612
Aug 11, 2015 07:19 PM
