Safe on Pump GAS
Old Mar 5, 2003 | 08:48 PM
KMAN's Avatar
Safe on Pump GAS
would this motor be safe on pump gas
http://www.strokermotor.com/383500LB.htm
Old Mar 5, 2003 | 09:21 PM
Guest
Guest
Posts: n/a
Define pump gas.
Its possible, but that combo is pushing it. I dont see the cam specs either, which is a factor.
Old Mar 5, 2003 | 09:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
tappity tap tap tap! no pump gas for that motor.
Old Mar 5, 2003 | 10:03 PM
KMAN's Avatar
pump gas as in 91 or 93, cam is matched to your application
Old Mar 6, 2003 | 12:40 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Just put a monster cam in it like a Comp Magnum 306 s solid cam. You should have a DCR of around 8.06.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
