Cam bearings
Old Mar 8, 2003 | 07:22 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Cam bearings
Well my motor started making this horrible screeching noise. It was so loud that it'd hurt your ears. I tore it down and everything looked normal until I noticed the cam bearing......
Old Mar 8, 2003 | 09:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks pretty normal for a cam bearing that's had metal shavings in it. That's not the source of your problem, it's a symptom; and as those things go, not a particularly terrible one.
Check the front of your block, on the inside, right opposite the crank timing gear, around the front main bearing. See if there's signs of rubbing there, and/or on the front of the front crank counterweight.
Old Mar 8, 2003 | 11:43 PM
Car: '89 IROC-Z
I'm gonna start pulling the motor tomorrow and see if I can find anything else. I'm almost glad this happened because now I have an excuse to build a better motor. It was just a matter of time before the unknown milage stock bottom end went out.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
anesthes
Aug 26, 2015 01:37 PM
