HOW do i get my FUEL filter off
Old Mar 10, 2003 | 08:25 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i cant seem to get my fuel filter off and i know i need to. never been changed but its so damn rusted on the threds it wont budge. i dont wanna break anything but think i should keep at it or have it changed somewhere????
Old Mar 10, 2003 | 08:41 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
mine was rusty, i just grabbed it with a pair of pliers and turned it like there was no tomorrow and off it came. just dont bounce up and down and yank and stuff, you dont wanna break the lines. also be careful when you get it off, gotta wear safety goggles! you dont want gas in your eyes. yeah so really no trick, just gorilla it off.
Old Mar 10, 2003 | 02:30 PM
Jza's Avatar
Jza
Use a backup wrench, and make sure it's a "line wrench" or "flare nut wrench". These are a whole lot less likely to round off fittings in the event of a seized fuel filter.
And, yes, do wear eye protection. Gas seems to burn a little more these days than it did just a few years ago.
Old Mar 10, 2003 | 09:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
if all else fails,, get a blow torch. that always works .
Old Mar 10, 2003 | 09:26 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
Bottled, don't tell him that. Kinda like smoking a cigarette in a fireworks factory,...........BOOOOOM!!!!!!
But seriously though,.....I noticed somthing on mine when I changed mine about a year ago. Actually two things. First off, I noticed that the filter is in a different location on my 92 than where it was located on my 90. When did they change the location? 91? Just curious. Second, When I got the filter off,...it poured gas like crazy. I thought that maybe when the lines had cleared that it would stop running. But it didn't. I filled a 5 gallon jug up before I figured out it wasn't gonna stop. It didn't do that on my 90 model. It quit running after a few minutes. Changing a fuel filter isn't for the faint at heart. It gives you the feeling of helplessness when your covered with gas, and you realize how "Explosive" you really are at that moment.
Old Mar 10, 2003 | 10:03 PM
383 rocket bird's Avatar
I would use some penetrating oil on the filter fittings. Can't believe no one mentioned that. Also using never cease on the threads upon reinstallation will eliminate this problem in the future. Good luck
Old Mar 11, 2003 | 08:13 PM
smkehndas's Avatar
Car: 02 Xtreme Blazer now
Engine: 4.3 v-6
Transmission: an automatic one! haha
the best penetrating (sp?) liquid i have found yet is called "mystic metal mover" this stuff works wonders!!!! if you need to break a nut loose or even drill a hole this stuff works great!
when i changed my fuel filter in my camaro it leaked a little bit but it was also a pain to get off!
Old Mar 12, 2003 | 11:00 AM
Vader's Avatar
Posted by CamaroRUS
HOW do i get my FUEL filter off?
Give it the 1-900-number for "Fuel Filter Fone Sex Hotties", Or buy the "Fuel Filters Gone Wild!" video, than give it some privacy for about ten minutes. While it's on the phone or freeze-framing the video, soak it at both ends with penetrating oil. It will appreciate the lubrication.
Blaster Formula PB is good, but even plain old WD-40 will work if you give it engough time.
You may actually have to soak it for a day or more, applying penetrant often enough to keep it wet.
When you install the new one, apply antiseize compound to the threads on both flare nuts.
As others have mentioned, use a flare nut wrench on the fittings and backup wrench on the hex of the filter body fitting.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
