best oil filter
Old Mar 17, 2003 | 07:57 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
best oil filter
who makes the best oil filter? i've been using a fram ph13 i think, its something like 13.
Old Mar 17, 2003 | 08:09 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
AC Delcos. Simple as that. Either the PF-25 or the PF-454S
Old Mar 17, 2003 | 08:15 PM
LYV18F's Avatar
do a search, somebody posted a link to a site that like took apart a whole bunch of oil filters and commented about them, it was pretty useful. i just changed my oil last week, and i used a fram tough guard i forget what number, i got it at walmart. the site recommended the tough gaurds, but it said the regular frams had like cardboard on the inside, and they leak a lot or something. you should check it out.
Old Mar 17, 2003 | 08:26 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
www.minimopar.net, I'm pretty sure this is the right link.
Old Mar 17, 2003 | 08:36 PM
Sluggo's Avatar
Definately Napa Gold. Consumer Reports did some tests years ago and Napa Gold out shone the competition in flow rates and cleaning rates. I haven't used anything else since. There may be better ones out there these days, but I haven't looked back since going to the gold.
Old Mar 17, 2003 | 08:55 PM
PonchoTA's Avatar
System 1 !!! Get thru Summit or Jegs. Yes, initially expensive, but with the Delcos (my 2nd best choice), not buying 9-10 of them will pay for the System 1. And you never throw it away!! Never contribute to more (hazmat) trash at the dump or landfill, and works better than most other paper-type filters.
My $0.02, hth
Old Mar 17, 2003 | 10:12 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I use a Mobile1 filter. its a little costly thoe around $11.00
Old Mar 18, 2003 | 05:56 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i use k&n
Old Mar 18, 2003 | 08:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's easy to conclude that the worst thing out there is Fram, from design to quality control. Advertising will beat quality for awhile, but the chickens are starting to come home to roost.
AMSOIL filters are manufactured by Hastings to AMSOIL specs. Corner a Hastings factory rep, he'll admit the AMSOIL filters are better than those with the Hastings name on them (and Hastings has very good products). The all have anti-drainback valves, the thickest/strongest case out there, and a filtering media that filters 10 micron absolute (which typically is 5 microns nominal) while maintaining a low delta-P.
The filter eval site is www.minimopar.net/oilfilterstudy.html . I've seen that site for a couple of years, and it has always said about the AMSOIL SDF-15: "This filter has been acquired, disassembled, and is awaiting measurements."
Old Mar 18, 2003 | 10:02 AM
82camaro's Avatar
Car: 82 camaro SC
previous talk about amsoil filters:
https://www.thirdgen.org/techbb2/sho...baldwin+amsoil
My Baldwin contact tells me the Amsoil filters(sdf) are the baldwin severe service filters.
Here are the two different filters:
http://www.pecuniary.com/synthetics/fullflowfltr.html
http://www.syntheticlubes.com/fleetof.html
http://www.baldwinfilter.com/products/lube.html
I usually use the baldwin filters, if I can find them--the local wal-mart carries them here.
If you want a pretty good, but cheap filter. The walmart 'supertech' filter is made by champ labs for less than 2 bucks. The funny part is the fram filters right next to them cost more and are very poor quality.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
