Who has eliminated the oil cooler?
Old Mar 19, 2003 | 09:05 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
Who has removed the oil cooler and what was involved? How much does the cooler actually help? Thanks
Gary
Old Mar 19, 2003 | 09:39 AM
85TPI400's Avatar
I often wonder myself if it is an oil cooler or an oil heater!
Old Mar 19, 2003 | 09:50 AM
bes217's Avatar
Why would you want to remove the oil cooler. It is there to protect your engine so that it will hopefully last a little longer.
Old Mar 19, 2003 | 10:38 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
These cars don't have engine oil coolers.... I wish I had a dry sump w/ an oil cooler
Old Mar 19, 2003 | 11:22 AM
ede's Avatar
ede
never done it, but i'd guess it's just a matter of plugging a few lines and tightening a few hose clamps. you have the one where coolent is flowed to the oil filter right? pretty silly design if you ask me, but then again i'm no automotive engineer. my old chevy truck and gmc jimmy have oil coolers in the radiator and the jimmy has remote oil filter, lot better design.
Old Mar 19, 2003 | 01:12 PM
iroc22's Avatar
RPO: KC4
Old Mar 19, 2003 | 01:17 PM
Jza's Avatar
Jza
Some did. I believe the G92s came with them.
Old Mar 19, 2003 | 02:10 PM
Z_Ghost's Avatar
I am on my car because the lines interfere with the 8" damper on the motor, later I am going to put a real oil cooler on it.
If you want to remove all of it you just unbolt the oil cooler adapter from the block, pull the filter off and you will see how to do it. Also there is an oil filter adapter under the oil cooler so you can screw the filter back on, you have to switch around how the coolant is rooted, but that is just 2 lines.
Old Mar 19, 2003 | 02:36 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Thanks guys. My main reasoning is the Edelbrock TES is right up against the frame and the coolers lines. I'm going to use the TES with this new combo and probably switch over to a set of long tube headers. Here's hoping for some high 11 time slips!!
Old Mar 19, 2003 | 04:00 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I got rid of mine, didn't seem too effective. I see it as one less place for coolant to leak.
Old Mar 19, 2003 | 08:31 PM
89IRO's Avatar
Is it a bad thing if you don't have an oil cooler? -89IRO
Old Mar 19, 2003 | 11:16 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
I went ahead and removed it tonight. I got tired of fighting the two lines where it attached to the housing . The Edelbrock TES header drops down right at that point and caused the flange to ride right against the frame. Only thing left is to do is drop in the distributor and superram tomorrow and maybe fire this new 383 up. It's almost done, finally!! Thanks again for the input guys.
Gary
Old Mar 20, 2003 | 12:20 AM
iroc22's Avatar
RPO: KC4
Coupled with G92 after 1986 IIRC.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
