mini cowl induction on stock hood
Old Mar 25, 2003 | 05:57 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
could you take some of that weatherstripping off that is right in the back of the hood for air flow in there sort of like a cowl induction. i have an open element air filter and i would like to get some cooler air to it.
Old Mar 25, 2003 | 07:24 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You can take that off and it will let hot air out better, help cooler air get to the cleaner from under and in front of the car, but I dought you will get much if any any performance increase, you can try it, just keep the rubber in case it leaks too much rain into the engine.
Old Mar 25, 2003 | 08:39 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
according to Vader..the windshields of these cars , wont allow the cowel hood to function..very well..so I doubt it would help much...this helped mine.. in spite of...
Old Mar 25, 2003 | 09:05 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i have a cowl scoop (same as rileys) the 2.5" Harwood and whenever it is raining i see water go off the back of the cowl then on its way down it goes into the space between the hood and scoop. the water droplets prolly go 3" to 4" into the hood before the hit the hood. i do have a hole cut in the hood for the air cleaner. so i know there is a good amount of air going in right there........
correct?
Old Mar 29, 2003 | 08:53 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Huh...go figure....Vader is always spot-on with his stuff. I picked up 4 tenths and 2 mph when I put mine on.
Old Mar 30, 2003 | 06:50 AM
Engine: 406
Maybe he just never tried it!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
