oil pan question
Old Mar 30, 2003 | 05:03 PM
black83z's Avatar
oil pan question
I am putting my 305 oil pan on my new 350. I have a set of fel pro gaskets. The instructions say to use quick drying adhesive on the rear main seal gasket. What kind of adhesive should i use? Should i put a bead of RTV on the oil pan gasket itself? Thanks for the help.
Matt
Old Mar 30, 2003 | 05:30 PM
ede's Avatar
ede
you shoulld give more info, like 1 or 2 piece seal. for 1 piece i use avation gasket sealer on the outter edge and white greese on the inner lip. 2 piece i use ultracopper o nthe ends of the seals wherethey meet and offset them in the cap and block a little. use ultracopper on the mating surface of the rear main cap. i use 1 piece oil pan gasket so i use nothing on the block, very thin layer of ultracopper on the pan. make sure you hammer out the dimples in the bolt holes.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
