3800 rpm and up, no gas?
Old Mar 31, 2003 | 07:59 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Here is the deal. Car is in the sig, but now with 3.42 gears. If I let it set and idle it "loads up" and when I get on it or even come close to opening the 4 bbls it bocks and bout dies. If I run it cold same thing. Doesnt matter the operating temp it does it. When I shut the car off I smell gas but no leaking. I know I have a bad exhaust leak but I doubt that is the problem (Collector gaskets). I am thinking carb needs rebuild, maybe a bad modul (sp?) (stock), or fouled plugs (caused by the other problems?). Its like it runs out of gas. I can get on it and it be fine, let of and drive for a few then get back on it and it misses and spudders. Please help because the drag strip opens in Muncie, IN on the 9th for test and tune nights and I need to be there!!!!
Thanks!
-Terry-
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Bradsaundry
Aug 12, 2015 12:34 AM
