Ignition module?
Old Apr 5, 2003 | 12:35 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Ignition module?
I'm trying to narrow down a stumbling problem my car has under light throttle. I installed a new Accel 300+ ignition last summer that "supposedly" bypasses the ignition module in the distributor. Could a faulty module, still affect drivability, even though its not an integral part anymore?
I'm pretty sure the problem is sensor or injector related, but I just want to know if I can rule the module out as a possibility.
Old Apr 5, 2003 | 04:27 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Anybody else have the Accel 300 ignition?
Old Apr 6, 2003 | 07:16 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
anybody?
Old Apr 6, 2003 | 10:27 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'm not sure what Accel means that they bypass the module? That doesn't seem possible. Maybe it overrides what the module says? I know that's the same thing as bypassing, but not really.
The only way to tell if the module is bad is take it out and over to AutoZone, Advance, etc. and have them check it. Even then it may seem OK on their test bench. So the only other option is to buy one adn try it, or unhook the Accel unit.
Old Apr 6, 2003 | 12:00 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Well, when I was buying the ignition from Summit, I thought I would buy an Accel module to go with it. They told me I didnt need the module because the 300+ box overides it. I was suspicious of this, so I called Accel and they said the same thing.
I was just wondering, if it is faulty, would it still cause problems.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
