Stock intake manifold
Old Apr 5, 2003 | 01:58 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
How good is the stock intake manifold? If i were to get a new one how much would it cost? I have a 350 TPI with mods in my sig. I am saving up money to have the top end of my engine get new performance parts and dress up parts. Thanks!
Old Apr 5, 2003 | 03:14 PM
88gtagearhead's Avatar
stock one sucks, best one for the money is the edelbrock, its around 350 bucks. get it at jegs or summit
Old Apr 5, 2003 | 03:29 PM
Vader's Avatar
Are you sticking with TPI, or have you considerd an LT1 intake?
Old Apr 5, 2003 | 06:06 PM
Im sticking with TPI. Also is it easy to port the pluenum and runners or should i get new ones?
Old Apr 5, 2003 | 06:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, it's easy to port the plenum, no need to waste time on the runners...when you have them off, you'll see what I mean.
Old Apr 5, 2003 | 07:17 PM
would it be just as good to have the stock manifold ported and polished then to buy a new one? so i should stick with stock runners or get new ones?
Old Apr 5, 2003 | 08:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you're after more RPMs and HP, then you'll want a better set of runners, the stock ones cannot be improved 9maybe minumally, not noticiably though) but you can port the base...depends on your budget, etc...or buy a new one with more meat to work with.
What's your goal? Could be you can get there with what you have, or you may need to upgrade.
Old Apr 5, 2003 | 08:59 PM
My goal is to have a very fast daily driver. I wanted to get it into the 10's but for a daily driver thats not going to hapen. I just want to be able to prove that automatics are not slow and waste those piece of crap ricers. I want to get it into the 12's though. Could i do that with stock runners and a ported intake manifold with the right other mods?
Old Apr 5, 2003 | 09:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I won't say "No" as a definte, I'm sure there are some who have dipped into the 12's with the stock top--shelf, but it's not going to happen for the most of us.
If 12's are your goal with FI/na, then you're best off looking for a new intake, heads and cam.
Old Apr 5, 2003 | 10:36 PM
well im getting my heads ported and polished,headers,ported/polished pluenum,racing wires/plugs,MSD ignition,24lb injectors, and maybe a port and polish my manifold unless i get a new one. All that along with the mods in my sig.
Old Apr 5, 2003 | 11:58 PM
kevin89formula's Avatar
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
BEST TIME I RAN WITH ARIZONA SPEED AND MARINE LARGE TUBE RUNNERS, PORTED PLENUM, AND PORTED INTAKE WAS 12.70 109 MPH. BY THE WAY THAT WAS WITH A 383, CAM AND AIR FLOW RESEARCH HEADS. I AM SELLING THESE RUNNERS, INTAKE, AND PLENUM FOR 435.00 UPS GROUND SHIP INCLUDED. IF YOUR INTERESTED. GOOD LUCK!
Old Apr 6, 2003 | 12:13 AM
but would i need a new intake manifold to run 12's or would a stock ported/polished one work? I have decided to get large tube runners.
Old Apr 6, 2003 | 12:21 AM
zerotosixtyV8's Avatar
Car: Camaro
save a lot of money and buy a Stealth Ram. TPI intakes are gonna fall flat on their face at 4500 rpm and the cost for complete largemouth base, runners, and plenum is way more than you'd ever want to spend. Stealth Ram is hundreds cheaper and will actually increase HP and not restrict you to a 4500 rpm limit! If you just want to see 12s with a TPI unit, you're gonna need a monster 406 or a 383, but why choke that motor so much, you could see 11s or lower with a better intake!
Old Apr 6, 2003 | 01:02 AM
Car: 89 formula 350
Transmission: t56
If your already having you stock heads ported I hope it turns out well for you. I had mine done many years ago and i did not see much inprovement. i finaly got smart and bought afr heads. if your spending the kind of money I think you are. or if your paying some one labor for the removel and install ( or if your wrenching yourself). I think you are better of buying new after market heads. i also agree with a another post, it will be hard to get in the 12's with stock ported heads and ported stock upper. you can always put the bottle on it , that will will get you were you want to be.
Old Apr 6, 2003 | 01:27 AM
Im getting the heads ported and polished (off the car) for about $300 out the door. Squeeks83 had them done and he said he noticed a big difference.
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
