nasty oil leak help! :(
Old Apr 6, 2003 | 07:10 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
well i had just finished my 350 swap and the car ran fine the first day except my oil sender unit was reporting 50 at idle and just pegs with any throttle - day two cam around and a small oil leak appeared - dripping of the right side of the bell housing - there also was a small drip on the oil filter so i tightened that a little more - day 3 comes around and the leak has turned major - i opened the flywheel check to look inside the bell housing - everything inside was saturated with oil - also my clutch was slipping if i gave it anything more than about 1/8th throttle - so im pretty sure its the rear main - which at the time of installation i was totally **** about sealing it right - any way my question is could it be anything else - i do not believe there are any freeze plugs in that area - my oil pump way suppose to be stock replacement and there shouldn't be any pressure in the crank case if it was even that high right? - my temp beater car was hit and pretty messed up so now with my camaro broken i have no way to get to college!
oh yeah when i stopped driving after about 15 mins, last time i drove it, smoke was billiowing out of the bellhousing - also i pulled the dipstick and the cap and smoke was comming out of there too - a lot less though but still...
Old Apr 6, 2003 | 10:08 AM
Vader's Avatar
There are oil gallery plugs in the rear face of the block. There is also a pressed plug over the rear of the camshaft bore. All of these are subjected to oil pressire, as well as the rear main seal.
Attached Thumbnails nasty oil leak help! :(-reargalleryplugs.jpg
Old Apr 6, 2003 | 12:59 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Is it leaking above the bellhousing and dripping down or is it actually coming out the back of the block inside the bellhousing?
Old Apr 6, 2003 | 09:27 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
it seems to be comming from inside the bell housing
gta892000
Aug 11, 2019 11:16 AM
Loudnproud86
Jul 14, 2016 12:59 AM
bamaboy0323
Sep 12, 2015 07:14 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
tgp1990
Sep 4, 2015 06:24 AM
