guestion about l98 head lift, lt4 hotcam :(
Old Apr 7, 2003 | 12:30 AM
FIREBIRD7777's Avatar
wasnt sure which forum to post this in, tpi, or tech, so here is the link , if anyone has the time to check it out, and advice , thanks in advance , https://www.thirdgen.org/techbb2/sho...98#post1237398
Old Apr 7, 2003 | 09:32 AM
Damon's Avatar
The springs are only one reason the L-98 heads can't go over .470. The bottom of the retainer hits the top of the valve guide seal. Stock springs will actually go beyond .500" of lift without binding (I'm measured them in a valvespring vice) but they don't stand a prayer of controlling the valve motion with an aftermarket cam in that lift range.
You need springs AND machine work the whittle the guides down a bit.
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Aug 31, 2015 06:04 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
