SPeedo Gears
Old Apr 8, 2003 | 07:36 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
SPeedo Gears
Hey all I have swaped my 2:72 Posi rear with a 4TH gen 3:23 posi W/ Disc rear. Do you have any idea on part numbers for the 3:23 speedo gears?
Brian Felts
Old Apr 8, 2003 | 09:25 PM
89WS-6's Avatar
no, but Im sure taht you could either go to GM, and get one without any knowledge, or you could try to find one in a junkyard. Good luck,
Old Apr 8, 2003 | 09:57 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
There are, I believe, 3 combos of speedo gear for 3.23. They are:
15T Grey (8642620) Drive, 39T Brown (1359273) Driven
16T Blue (8640518) Drive, 42T Green (1362049) Driven
17T Red (8640517) Drive, 44T Dk. Grey (9780470) Driven
Robert
Old Apr 9, 2003 | 12:10 PM
jawzforlife1's Avatar
When I went from 3.08 to 3.23 rear end, I got the gray gear, but never put it in, If you want to buy it, let me know. It is a GM part.
-JAWZ
Old Apr 9, 2003 | 02:11 PM
jawzforlife1 : Yeah I wouyld be interested in your gear but how close would it put me to being correct?
Brian
Old Apr 9, 2003 | 02:19 PM
When I got mine I wend to the Gm dealer and told them I was doing a rear rend swap. I was putting in a 1993 Z28 (3.28)rear end into a 1991 camaro (3.08) and said what gear I would need. I dont remenber exacytly how he figuried it out, but I think he used some math using the nymber of teeth on the grear. (Ithink you need it to be a certian ratio) and the gray gear gave me the closet ratio to go from 3.08 to 3.23 rear end. Sorry I dont know how exaclty he fiquied it out, but it only took about 5 min to fiquie it.???
Old Apr 9, 2003 | 02:24 PM
jawzforlife1
You have a PM...
Brian
Old Apr 9, 2003 | 03:35 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
http://www.sallee-chevrolet.com/ChevyTransmissions/4L60_Installation.html
should have everything you need to know about the speedo gears....
-brian
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
