Knock Sensor
Old Apr 15, 2003 | 02:37 PM
mpitts77's Avatar
Knock Sensor
While I was undering my 92 RS pokeing around..i found the knock sensor...which the connector was broken off. Does this need to be hooked up?
Old Apr 15, 2003 | 02:46 PM
CrispyClutch's Avatar
I'm pretty sure it's only there for looks
Old Apr 15, 2003 | 03:07 PM
mpitts77's Avatar
Well I hope everything else that i've found that is broken/not hooked up is just for looks =D
Old Apr 15, 2003 | 03:17 PM
You prolly ought to hook it up.
Old Apr 15, 2003 | 03:38 PM
mpitts77's Avatar
Think i can get a connector from GM? or just rig something up
Old Apr 15, 2003 | 04:06 PM
Yeah but I think I would rather fabricate something.
Old Apr 27, 2003 | 01:09 AM
SpectreGTA91's Avatar
Where is the knock sensor located anyway?
Old Apr 27, 2003 | 10:16 AM
flyway190's Avatar
The knock sensor should definitely be hooked up, I'm kind of surprised you haven't noticed anything strange. It should use the same connector as the fan switch. You might try going to a junkyard to find a connector because many GM vehicles used that kind of connector starting somewhere in the early-mid eighties.
The knock sensor is usually located in the block on the passenger side, though it can be located in the same place on the driver's side. Not to be confused with the fan switch, which is located in the passenger side head between plugs 6 and 8.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
