Turbo GTA Project...Update #3...IT'S DONE!!
Old Jun 9, 2000 | 02:41 AM
Brendan's Avatar
We are finished save a few minor things to work out! My red GTA now has a TTA 3.8 V6 and it runs GREAT! We cranked it for the first time last night and it started right up very easily. Ran it for about 20min. till it warmed up. Hooked the OTC 4000 up to the ALDL and scaned it for codes...none. Everything seems to check out okay. The real test will be tomorrow when we test drive it for the first time. If all goes as planned this thing should be a very bad a$$ car!
~Brendan
1988 Turbo GTA Trans Am - 3.8L V6 turbo w/ 700-R4
"There IS a replacement for displacement!"
It's still under construction but:
http://turbogta.homestead.com/main.html
Old Jun 9, 2000 | 06:50 AM
Gigolo's Avatar
What made you decide to put a 3.8 turbo in your car instead of say..... putting a turbo or a supercharger on a 350? Im not bashing you. I want to do something along the line of one of these 3 and just wanna know your reasoning. Congratulations
Old Jun 9, 2000 | 07:32 AM
TTA's Avatar
TTA
Sweeet! Lemme know if you need any tuning help... Just touch the thing and it will run low 12s....
Mike
TTA89 (someone already had my nick)
1989 Turbo Trans-Am
11.42@119.60
"Best Pontiac Buick Ever Built!"
Old Jun 9, 2000 | 02:22 PM
Get Blown ?'s Avatar
Gigelo because the Buick 3.8 is one mean ****. You can make 3HP per C.I. with ease and stock it makes more torque then a 350TPI.
Old Jun 9, 2000 | 02:47 PM
Brendan's Avatar
Gigolo: Get Blown? said it. It will make tons of power, and like Mike said it will go 12's if you touch it right! I was going to have to rebuild the 350TPI I had because it was way down on power; ran 16.20's and had a 140K miles. That would have cost some money and then adding a supercharger would have been even more cash. A turbo 350 was pretty much out of the question because it would have to be a custom fabricated setup. I swapped in the 3.8 for less money, it will make more power (disclaimer: 'In my opinion'...don't want to start another fight), and will go faster. This engine is stock except for forged pistons; stock cam, heads, turbo, intercooler, chip, etc... and I'm hoping for mid-13's which should be a realistic goal I think. That's pretty much why I did it. BTW it's so much easier to work on than the 350 was and it gets better gas mileage.
~Brendan
Old Jun 9, 2000 | 02:50 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Awesome!!!!!!!! Probably 12's w/ some small mods
Justin 87 GTA--Moderator/Originater: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.67 @ 100.
http:// www.community.webtv.net/munks87/JustinsGTApage.com
Old Jun 9, 2000 | 02:57 PM
88gta,chris's Avatar
Would it be even faster than a 350tpi with aftermarket heads, cam, vortech supercharger and a 6speed? This was what i was leaning towards. Gas mileage is not an issue. I only live 7miles from work
88 GTA 350TPI
Current MODS: TPIS AFPR, K&N Cone filter, Modified maf, TPIS air foil, Hypertech Fan Switch and 160 deg stat, Jamex 1.5" springs, CATCO high flow cat, Edelbrock 3" cat back.
71 Formula 400. Not even close to stock
geocities.com/gta88_71/Test.htm
Old Jun 9, 2000 | 03:00 PM
89Iroc's Avatar
Congrats, even though those 3.8 turbos move, i still like my V-8's. you will be able to go low 12s pretty easy. I wanna one day try to do that with 3.8-or 4.3 without a turbo.
[This message has been edited by 89Iroc (edited June 10, 2000).]
Old Jun 9, 2000 | 03:30 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Do you have any pics of the car?I'd love to see a TTA in red.
Steve
TTA#850,bone stock,best 13.68@100
TTA#861,near stock,no times yet
89 GTA,nowhere near stock,soon to be low 10's
TTA's Avatar
TTA
~Brendan
Mid 13s??? HAHAHAHA... Why? You going to let off at half track?
Your not really running the stock chip are you??
Mike
1989 Turbo Trans-Am
11.42@119.60
Old Jun 9, 2000 | 03:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Congrats on the swap!! Where the HECK did you find a TTA motor? I've only seen one in "real life", and it wasn't in a junkyard
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jun 9, 2000 | 05:48 PM
Mike83Z's Avatar
Why did you use the 3.8L?
Old Jun 9, 2000 | 10:13 PM
Grandnat's Avatar
Originally posted by 89Iroc:
Congrats, even though those 3.1 turbos move, i still like my V-8's. you will be able to go low 12s pretty easy. I wanna one day try to do that with 3.8-or 4.3 without a turbo.
uhhhhh it is a 3.8 turbo. you must be thinking of the turbo grand prixs, they are the one with the WEAK 3.1L turbo motors.
Would it be even faster than a 350tpi with aftermarket heads, cam, vortech supercharger and a 6speed? This was what i was leaning towards. Gas mileage is not an issue. I only live 7miles from work.
well ask Mike....he runs mid 11s and is only mildly modded...his motor has never been open. that should tell you something...and if you can't read between the lines...the answer is YES!! not to mention MUCH MUCH cheaper!
[This message has been edited by Grandnat (edited June 09, 2000).]
Old Jun 10, 2000 | 02:21 AM
Brendan's Avatar
Steve: I've got pictures of the whole thing from beginning to end. As soon as I get them developed I'll scan and post them.
Mike(TTA): The mid-13's estimate is high, but I don't want to be disappointed. And yes to start I'm using the stock chip. I'm running closer to 9.0:1 compression with the TRW forged pistons; lower boost levels and more conservative timing will hopefully keep me from knocking. This is just to test this combination out so I don't go right out and blow a head gasket first thing. Then maybe a mild street chip or custom chip is in order.
TomP: I got the engine from a friend who's owned a few TTA's and had a couple extra engines. I got really lucky basically.
Grandnat: You coming over tomorrow night?
~Brendan
Old Jun 10, 2000 | 05:23 AM
chasmanian's Avatar
Car: 1989 White Firebird
how much did the entire project cost?
chas
Old Jun 10, 2000 | 10:12 AM
crazeinc's Avatar
Alright, it's tomorrow....How'd she run?!
-'82 Z28
-'96 Grand Am
AIM: fillup82Z
Old Jun 10, 2000 | 12:31 PM
TTA's Avatar
TTA
Its going to run like sheeet with the stock chip. I understand your thinking but in my opinion your wrong. Its Possible to pickup 50-60hp from a chip in these cars. Yep, You read that correctly.
The Stock Chip is a POS to start with, its setup to make 16.5psi with the factory settings which is fine for the street but its setup for an 8:1 motor. Your motor is 9:1 not 8:1 your going to be running into problems and have more of a chance of detination.
IF I were you, I would call Joe Lubrant at PTE and tell him that you have 9:1 compression and you need him to cut you a chip. I have no idea how much boost your going to be able to run with 9:1, maybe 14-15psi on pumpgas I would think. Thats just my guess outa the air.
Be Careful.....
Mike
1989 Turbo Trans-Am
11.42@119.60
Old Jun 10, 2000 | 12:45 PM
And you can use a GNX aftermarket chip in a TTA. It will control the Buick motor perfectly and yes even your 700-r4. Or at least I think that's correct...I haven't looked into Buick turbo motors in some time.
[This message has been edited by Get Blown ? (edited June 10, 2000).]
Old Jun 10, 2000 | 03:16 PM
TTA's Avatar
TTA
The GNX, GN and Turbo T/As all use the same ECM but have different programs in there stock chips. You can interchange them if you want to, but they all still suck.
You spent all this money doing the swap, call PTE and spend another 50 bucks on a chip so you can actually enjoy the ride that you just built.
Last wednesday night this guy showed up at the track with a Bone Stock 87 T-type. He was running low 14s at 99mph. The traction was horrible so the ET's for everyone sucked.
Anyways, He took out the Stock Chip and Put in a Modern Muscle RaceChip and I found a piece of wire in my truck that I gave to him to "Short" the Terminals in the ALDL to lock up the convertor as its going down the track. First Pass with the same boost levels the car went 13.87@105mph...
Forget about the ET, look at the MPH. 6mph from a chip and a piece of wire. 105 is good enough for 12s with traction...
These cars are BIG time computer dependant. The chips make or break you. Ok, I am done preaching its your car. Hope Your out having fun with it!!
Mike
1989 Turbo Trans-Am
11.42@119.60
Old Jun 10, 2000 | 06:20 PM
MAMASAIDKOUOUT's Avatar
sweet you got it done! good luck tuning. hey wanna race?
Old Jun 11, 2000 | 02:17 AM
Brendan's Avatar
Mike, you took the words right out of my mouth! Dan Nevin is the guy that really helped me with this swap. Dan, Grandnat, and I all agreed that I am going to call Joe Lubrant up ASAP and get a custom chip for this setup. The car definitely likes the stock TTA chip better than any aftermarket chip Dan has (he's got tons of them...from ATR to Conley to Thrasher). With the stock chip the car runs a max boost of 14psi (I don't know why, ideas?) and a pretty rich mixture. It does have a tendency to detonate still, possibly still too much timing? I'll give Joe a call on Monday and see what he recommends?
Okay, now how does it run??? Even in this current state, out of tune, it still pulls...HARD. I raced Dan's TTA (TA-49 turbo, chip, K&N, downpipe), it's run a best of 12.9 @ 110mph. We ran from a dead stop. He pulled 2-3 cars on me at the launch but once I got moving he stopped pulling and I actually started to creep up on him to about 80mph. On the highway we were pretty close, I was on his rear bumper and actually started to pull on him slightly from a 55 roll...we have neat tail lights BTW!
This car is going to be a fast car once we get it tuned correctly. Not bad for about $2000 ($3000 for the car!)!
~Brendan
Old Jun 11, 2000 | 09:21 AM
TTA's Avatar
TTA
Do you have an adjustable wastegate rod? Screw it in 2 turns (Shorten the Rod) and that should bring you up to 16psi. Just check it out on a scantool to see whats going on....
Mike
1989 Turbo Trans-Am
11.42@119.60
Old Jun 11, 2000 | 01:25 PM
89ROC's Avatar
OK I see why you did the swap now...$2000 is a killer deal! Congrats.
What all did you have to do to make the wiring harness work with the turbo V6?
Or did you have to get a whole new harness?
Can't wait to run ya .
A bunch of us are going down to Ennis next weekend. If all goes well, come down with us.
See ya
89' Iroc-Z
ZZ3 short block-355 CID w/ TPI, 10.4:1 compression; forged TRW pistons, plasma-moly rings. Edelbrock performer heads & 3" exhaust. ZZ9 cam w/ 1.52 roller rockers. Plus NOS 150 shot. 95' T-56, 6spd trans. 99' Z' rearend w/ 4.10's
Old Jun 11, 2000 | 06:08 PM
Grandnat's Avatar
Hey Brendan the stock chips are high in timing..and that causes Detonation.....especially on a 9 to 1 motor with 14 psi of boost. I did some checking and I found out that on a 9 to 1 compression motor it is very similar to increasing boost 3-4 psi....in other words on a 8:1 motor if you run 18 psi on 93 octane and are getting a little knock......with a 9:1 motor you could only get away with 13-14psi....so actually you are right where you want to be..and that explains the knock..BTW we talked about this last night but I didn't have all the facts..but it turned out that is the case after I did a little on line checking.
BTW the only reason the TTA was pulling you from the start is because he has a 2200 stall converter stock....your 1800 converter is not mad for a turbo car and thus does a really bad job of spooling the turbo.
get the small stuff taken care of and that thing will rock.
we still need to figure out the rich problem....I have a bad feeling it is the MAF...but get an adjustable FP regulator and turn it down 2-3 psi and see if it clears up.
talk to you later...BTW I am free wed if you want to hook up Tlink and do some more tweaking.
Old Jun 11, 2000 | 06:20 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
dammit!!!! now i want one!!!!!!!!!!! all this talk about tta's has got me saving... i want one so bad!
Steve
brendan- maybe you could write a tech article of some sort, outlining the different things that have to be done, liek wiring and such
Steve
Old Jun 12, 2000 | 01:20 AM
Brendan's Avatar
I may consider a tech article on this swap but then it wouldn't be a secret! Actually everything (at least the big things) you need to know is covered in the FAQ section on this site. But just to convince those of you thinking about an engine swap THIS THING IS BAD A$$!
I'd love to take this car to the track right away and see what it runs. However, there are a few tuning issues that have to be sorted out before that happens. In fact, with this car running right it will be faster than it is now and I'm sure I'll be happier with the results.
Grandnat: I'm off tomorrow but I have to work Wed. 4-10p. I have been taking it easy on the car today. I borrowed the OTC 4000 from work (same as Dan's) and are trying to keep tabs on a few things. It's running hot, at least compared to Dan's TTA, around 200*. Lowering that temp. might help to lessen detonation. Maybe I should start buying gas somewhere else? I'd be happier with 0* knock retard. Right know I'm seeing about 7-8* knock retard. 1st gear I get 0* knock. I noticed one thing last night, though, the boost isn't pulled down to lower levels in 2nd and 3rd gear like the aftermarket chips do. Besides the rich mixture problem do you think that a custom chip will solve a few problems? I can order a few MAF's in and we can see which is the best. Should the MAF be maxed out to 255 with stock boost levels? What was my O2 voltage last night at WOT? I'm going to call Steve Kaminski tomorrow and see what he says since he's familiar with this setup. In the meantime I'll take it easy.
BTW I'm planning on getting a stock Corvette torque converter; they stall around 2200-2400rpms and they are reasonable priced from what I hear.
~Brendan
It's still under construction but: http://turbogta.homestead.com/main.html
[This message has been edited by Brendan (edited June 11, 2000).]
Old Jun 12, 2000 | 01:52 AM
PMD Power's Avatar
You ever find out how your gonna get rid of thats TPI 350??
Just wondering...I need power BAD...
Chris
PMD Power
79 T/A WS6 455 valve problem...uh oh..
91 Firebird 305 TBI..Some ultimate TBI mods finally!!
Old Jul 23, 2000 | 10:09 PM
Ratnose86SC's Avatar
Hey Brendan,
In the pic on your website are you parked out front of O'Reilys?
Im pretty sure that i just saw your car today when i went to get some stuff. Ive seen it there before, but have never seen the gold TURBO emblem on it.
Looks real nice. Ive seen you drive by the Sonic on Custer before. I work at the Express Lube right there.
What area of Plano are you in?
Old Jul 24, 2000 | 01:19 AM
MacEwen's Avatar
Car: 88 GTA
Engine: 350, 383
Transmission: T-56 & 700R4
Brendan,
You kept the 700R4?
I thought the Pontiac (BOP) block has a different bellhousing bolt pattern. Did you have mod the trans? or use an adaptor?
Ryan MacEwen Pruyn
MacEwen Motorsports
1987 GTA 350 6spd, White OEM instruments, 17" Borbet Type A's, 275/40ZR17's, 255/45ZR17's, Koni Sport Adjustables, Eichbach Sport Springs, Poly U, everywhere, Guldstrand Engineering Panhard rod, LCA's
Old Jul 24, 2000 | 11:51 AM
Brendan's Avatar
The 231 block does use a BOP bolt pattern. I bought a TCI trans adapter (pn# 230001) and it bolted right up pretty easily.
Works great with the 700. I still have the stock torque converter which seems to be stalling at 1600rpm and is not going to cut it. I can't build any boost pressure at the line without spinning my tires. The original TTA's came with a 2200-2400 stall I believe similar to the 'Vette.
Ratnose: What Express Lube is that? Is there one at Custer and 15th? I know of the one at Coit and Parker. You guys do inspection?
Old Jul 24, 2000 | 08:56 PM
yeah its at 15th and Custer, tucked between the Sonic and the 7-Eleven.
yeah we do inspections, wish i was an inspector so i could do the brake test
Im just a lowly courtesy boy.
Stop by some time, id love to se your GTA.
Old Jul 24, 2000 | 09:08 PM
Brendan's Avatar
My topic is on fire!
Yeah I'll stop by some time when I'm in the area. I've got a friend that works at the AutoZone across the street; he drives the light green '65 Mustang. Speaking of...why are you shopping at AutoZone?!?! Most of their parts are junk and those guys are sometimes lacking in the 'know-how' department. Do you guys have any 'corupt' inspectors? I need to get my car inspected. I'm only missing a closed air box; I've got a cat, etc....
~Brendan
Old May 14, 2002 | 09:44 AM
SheckyZ28's Avatar
How do you guys like the 3.8 with the 700r4?
TX-SleeperC5
Feb 24, 2016 01:34 PM
2MNYMaros
Sep 15, 2015 11:36 PM
earlpote
Sep 12, 2015 11:55 AM
machinist21
Sep 5, 2015 03:03 PM
