cam question
Old Apr 18, 2003 | 11:45 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
cam question
my 91 lb9 came with a hydrualic roller cam with hydrualic flat tappet lifters correct...
a 94 lt1 motor cam with the same cam but with hydrualic roller lifters right?...
im wondering if i can use a "regualar'' hydraulic cam in a lt1 motor..i dont have 300 for a cam and another 250 for lifters
i was looking at comps cam kit for $189 with cam and lifters
Old Apr 19, 2003 | 12:02 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
If your car is a 91 then it has a hydraulic roller cam, and hydraulic roller lifters as well.
Old Apr 19, 2003 | 05:50 AM
85TPI400's Avatar
Exactly! unless somone changed it to a flat tappet.
I am not an lt1 guru by any means but I dont think you can put in a regular flat tappet old style cam into a newer lt1, without modification anyway! I am almost sure I read that the newer lt1 cams have quite a bit longer dowel in front that goes through the timing chain and actually drives something. (Water pump)?
Anyway this will bring your post to the top again and possibly someone else can clear this up.
Good luck!
Old Apr 19, 2003 | 07:26 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Opti-spark Distributer....the dowel was changed after 94 and is quite a bit longer...but can be changed
Old Apr 19, 2003 | 07:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually you don't have to replace roller lifters when you put in a new cam, like you do flat tappet ones. So that's a cost you shouldn't need to be concerend about.
Don't go out of your way to invent ways to downgrade your motor. That's kind of stupid.... spend whatever it takes to get this nice motor, then immediately start chippining away at the things that are good about it.
Old Apr 19, 2003 | 08:05 AM
Engine: 406
Old Apr 20, 2003 | 12:26 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
the cam also drives the waterpump...
well i bought my buddies headers and exhaust yesterday for 100 bucks...so that freed up 400 bucks or so,..
i havent torn down my lb9 yet but im pretty sure the lifters are still in good shape..so i wont have to get a set fo those
so just a 300 dollar cam lol
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
