Installing a 14x4 open air element (K&N)-question within
Old Jul 23, 2000 | 09:57 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
For whoever has done this mod, did you remove the gold spacer before installing the air filter or did you keep it on there? Also, where is the best place to relocate the IAT sensor ( i know it should be a cool place, so maybe right under my cowl hood next to the windshield? ) and how should i go about doing this? thanks
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter
Eibach springs with KYB's are already installed up front. Gonna work on the rear soon.
Appearance: Harwood cowl hood, Z-28 wing, painted black-original color was light blue)
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Going to the track this summer, but i'm pretty sure i'm still in the 16's on the 1/4 mile (or maybe not any more)
Old Jul 23, 2000 | 10:28 PM
dtpmike's Avatar
I left the spacer on, I also had to cut a snip out of it and then I just cut a hole through the open element and put it in there.
89 camaro 305 tbi, dynomax cat back(just switched to flomaster 3 chamber cat back), Edlebrock open element, 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit. Full leather interior from MrMikes.com
Old Jul 24, 2000 | 10:36 PM
Car: 88 IROC
Transmission: auto
Thanks Mike, anyone else please? I think i want to get rid of it. I know tons of you guys have done this already.
Old Jul 24, 2000 | 10:41 PM
AZDave's Avatar
If you use a drop-base air cleaner, you must retain the ring.
If you use a level-base air cleaner, you don't need the ring and flow is improved.
I mounted the IAT using an old spark plug loom bracket, just hog ouot the plastic to match the sensor diameter and mount it on the firewall, or in another path of fresh air.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mdtoren
Aug 23, 2015 12:52 PM
wruiz
Aug 13, 2015 09:07 PM
