Carb or Electrical?
Old Apr 19, 2003 | 04:19 PM
Trevor K's Avatar
Carb or Electrical?
OK, so I had my car running fine (Slight miss, but still definetely driveable), then I swapped rear-ends and bleed the brakes all around.
Now, when I start the car it starts up, but when the choke kicks off, the car idles down to about 500, sputters, dies.
Now, I can drive the car, but when I'm at a set of lights it does the same thing, sputters around 500RPMs, then dies. (I end up holding the gas a bit to 750RPM while holding the brake).
Now it's the the point where I put it in park on my driveway (After a 30 minute drive), go inside the garage (To open the garage door) and by the time I get out it is dead.
It looks like it's getting fuel (When I look into the carb I see two streams that aren't jerky/sporadic). But it still misses, and will die on me in gear all the time.
I took a long shot, maybe moisture in the cap from sitting all winter, so I took it off and sprayed it out with compressed air but it still didn't make a difference. I don't here any hissing (vacuum leaks) either.
And I know not much about carb's - and the guy who did my carb work is gone until at least tomorrow night in another province (And I did have plans for tomorrow afternoon).
Any ideas? It's an 87 305, non-CC quadrajet. And the quadrajet was just rebuilt last summer, ran perfect.
Old Apr 19, 2003 | 11:19 PM
Trevor K's Avatar
Anyone?
I'm dying for ideas here...
Old Apr 19, 2003 | 11:45 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
So it almost always dies when the choke is off at idle?
Old Apr 20, 2003 | 12:36 AM
Trevor K's Avatar
Yes, when the choke comes off it dies.
I figured maybe the choke is coming off too soon, so I'll drive it around for a bit (15-20 minutes, should be more than enough time I figure). Bring it to a set of lights, it stalls. Park it in my driveway after the drive, go to open my garage door (I didn't have the opener on me), and it has stalled by the time I get out.
I'm really at a loss for ideas - probably because I'm not the most knowledgable when it comes to carbs, so I'm not sure if this could be a carb problem.
Old Apr 20, 2003 | 12:38 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Well, I don't know that much either, but what if you raised your idle?
Old Apr 20, 2003 | 01:01 AM
Trevor K's Avatar
Yup - tried that, but it is backfiring too so I'm pretty sure it's not the idle screw.
Old Apr 20, 2003 | 04:40 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Your timing is off big time, check it with a light.
Old Apr 20, 2003 | 04:41 PM
Trevor K's Avatar
While I run to a buddy's place to grab a gun - How do you think the timing would all of the sudden go off like that?
Old Apr 20, 2003 | 04:59 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Maybe your hold down loosened up. Happen to a buddies Superrammed GTA and it ran like crap for a while.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
codeysabatini
Nov 10, 2015 04:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
