how should i set my fuel pressure regulator?
Old Apr 19, 2003 | 08:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i have a mallory 4309 fuel pressure regulator.. how should i set it.. with the fuel pump running or should i have the car running as well? what should the pressure be around 6-8 psi? also what does the vaccum port on the regulator do? will it increase pressure when vaccum drops?if so do i need to set pressure lower so it maxes out at 8ish? any info would be appreciated thanx guys
Old Apr 19, 2003 | 10:06 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
What kind of fuel setup do you have? TBI? TPI? Carb?
a TPI will run at 40 or so PSI at idle. Carb at 6-8 or so.
sorry I don't know how to adjust it.
Old Apr 20, 2003 | 06:02 PM
89RsPower!'s Avatar
oops thought i included that.. carb hehe
Old Apr 20, 2003 | 06:25 PM
Rancid87's Avatar
Set it with the car running. Run 7psi. You don't need the vac. port unless you are running a supercharger.
Old Apr 20, 2003 | 06:41 PM
89RsPower!'s Avatar
ah ok thanx! i wasnt sure what that was for
Old Apr 20, 2003 | 09:36 PM
Rancid87's Avatar
you're welcome and good luck.
Old Apr 29, 2003 | 10:58 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
well there isnt really a "set" fuel pressure
if 2 or 3 psi is enough to keep your floats full under all conditions then thats all u need
keep knocking it down till the car sputters then kick it up only as much as it takes to go away..
ccheck your A/F ratoi be make sure then your set
Old Apr 30, 2003 | 12:36 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i run 5 psi and the idle and all is great. like what was said, mess around until your float and everything seems adjusted correctly
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
