Fuse labeled ARC, blown but no explanation in Haynes, whats it for??
Old Jul 23, 2000 | 03:39 PM
pianiy's Avatar
Ok, I just took a 225 mile trip a few days ago and at the end of it my check engine light came on... the code said 44-Lean Fuel Mixture... the car has been running fine at idle but when you put it in gear and step on the gas it bogs down and when you floor it it simply stalls... now, I was about to start replacing different parts of it starting with the fuel filter but when I went to pull the fuse for the fuel pump there WASN'T any and there is NO contact in the ALDL for G to try to energize the fuel pump... I did find a blown fuse though with the label of ARC and have no clue what its for... and neither the Haynes or Chiltons manuals tell me... right now I'm resetting the ECM to clear the code and will go out for a test drive after replacing that fuse to see if thats the problem.. but does anybody know what its supposed to be for or why I dont have a fuel pump fuse or ALDL contact for it?? This is mind boggling... its for the '91 listed below... thanks
'91 Firebird
305/TBI/700R4/T-tops all stock
K&N Air Filter
Pioneer DEH-P8200R
Pioneer 6x9's
Kenwood 8" Tube
'87 Firebird
2.8L/MPFI/700R4/220K Miles on its original, never been rebuilt engine!
Car being parted and sold, just ask what I have.
[This message has been edited by pianiy (edited July 23, 2000).]
Old Jul 23, 2000 | 05:41 PM
Vader's Avatar
pianiy,
Do you have an owners' manual? Most of the fuse designations are outlined there, or inside the cover for the fuse panel. Usually the designations are an acronym for something, but I could only guess as to what "ARC" is supposed to be.
Later,
Vader
"Some Body...Someone"
Old Jul 23, 2000 | 10:09 PM
pianiy's Avatar
well.... I the car is running just fine now after replacing that fuse.... whatever it was, it did it.. and the car's been through 6 owners, yes 6, so the manual is nowhere to be found... I'm thinking of ordering it from GM, is it really worth it?
Old Jul 24, 2000 | 12:55 AM
Kevin S's Avatar
It wouldn't hurt to have a owners manual.
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Thinking seriously about Nitrous........
It's Not How You Pick Your Nose, But Where You Put The
Booger.
Old Jul 24, 2000 | 11:46 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think mine was $12 from Helms, who writes the GM books. Might as well order yourself a GM service manual too- well worth it! http://www.helminc.com
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jul 25, 2000 | 02:54 PM
witchdr's Avatar
Hey TomP- how or who do I contact to order those books?
`85 Z28 5.0L TBI
Don't ever be:
Found On Road Dead!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rd gen money
Oct 11, 2019 09:57 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thaney9
Oct 24, 2015 07:26 PM
tattmann
Sep 27, 2015 05:20 PM
