do I need a new oil sending unit?
Old Apr 22, 2003 | 08:42 PM
Chuck Haynes's Avatar
Hey
I just bought a 1990 IROC-Z (350/700R4)... The Oil Pressure Guage moves back and forth a lot. The guy I bought it from said that his mechanic said it just needed a new oil sending unit... Could this be possible?
-Thanks
Old Apr 22, 2003 | 09:20 PM
v8unleashed's Avatar
yes.
Old Apr 22, 2003 | 10:39 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Could be. Or you could just get a whole new mechanical oil pressure guage since GM factory gauges are junk.
Old Apr 23, 2003 | 10:38 PM
Okay, after examining the situation a little more... I found out that the gauge doesn't really move back and forth a lot... it just seems to be low. My last car ('88 IROC) had a Jasper 355 and it's Oil Pressure was at like 40 at idle and like 60 when driving. This car (the '90 IROC) idles at like 15 and goes to 30 while driving? Is that TOO LOW? Should I go ahead and put in a new Oil Sending Unit and see if that helps?
-Thanks
Old Apr 23, 2003 | 10:41 PM
YES!
Old Apr 23, 2003 | 11:59 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
-Thanks
My 305 has worked like that for ages. It isn't "spec" but will still run fine. If you're worried, use a little heavier oil like 10W40, 15W40 or even 50 weight.
Old Apr 24, 2003 | 08:27 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Sounds like the sending unit. It is pretty common for them to read low when they get old. It is above the oil filter and really not that hard to replace.
Old Apr 24, 2003 | 10:40 AM
MD83Z's Avatar
You could replace the oil pump first, like I did, and then do the easy job (sending unit ) last .
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
