Sometimes my car dies at idle. Help.
Old Apr 23, 2003 | 12:06 PM
firebirdkid's Avatar
Sometimes when I am at idle at a light, the car will stall. Currently, in drive, i idle at 500. Would the reason for the problem be that this idle is too low? I heard that it should be 600-650 in drive. Is the problem that I am idleing too low? I know how to set it higher, I just need to know if this would solve my stalling problem. Thank you.
Old Apr 23, 2003 | 04:00 PM
NE1?
Old Apr 23, 2003 | 07:10 PM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
My 85 IROC wants to do the same thing. It was fine until I tried using some fuel injection cleaner. I think it crudded-up one of my injectors instead of cleaning them out. Your case may be different, however.
Old Apr 23, 2003 | 07:39 PM
idrag2's Avatar
Try this. Turn on your a/c and see if the car idles up, if not get check your idle air control valve.
Old Apr 23, 2003 | 11:16 PM
i dont have ac. i removed it. i had a feeling it would be the IAC. so if i clean it and raise it i should be fine? thanks.
Old Apr 23, 2003 | 11:41 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Have you tried checking for codes? My '85 did the same thing once. It turned out to be the MAF sensor. The CE light never came on but when I checked the codes that is what came up. Replaced the MAF, it's been running like a champ ever since.
Old Apr 24, 2003 | 11:16 AM
thanks alot man
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
