Oil squirts out of bottom of dipstick
Old Apr 24, 2003 | 04:20 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
At least thats where i think it's comming from, i was told that was a problem with crank case pressure, and that my PCV system wasnt working, however i dont have a pcv system, i just run breathers on top of both valve covers, so what seems to be the problem, anybody with expirence plz respond...thanx doodz
Old Apr 24, 2003 | 08:02 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I'm having the same problem. I replaced my PCV and it's still leaking.
I just replaced a head gasket and the tube pulled out when I removed the headers so I assume the seal from all of the silicone finally gave. I removed the tube and tried more RTV (after cleaning it off) but it still leaks. I did notice that when I secure the tube with the header bolt it doesn't slide in all the way to the side of the pan.
I assume that's where it's coming from anyways because my heat shield for my starter is soaked with oil and it's dripping on to my exhaust.
Old Apr 25, 2003 | 04:46 PM
91Z28's Avatar
Car: 91' Z28
Danny, dude thats the EXACT same problem i have, WTF can we do about it, is it bad for the motor, i mean is there lots of pressure built up in the motor crank case to cause this, or is the dipstick just not secure ?
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
