Tranny Cooler as Fuel Cooler
Old Apr 24, 2003 | 10:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
What would be the effects of using a transmission cooler mounted in front the radiator and running fuel through it. Obviously this isn't going to help has much as a cool can, but it also doesn't require the effort of one. This is for a carb (low pressure) application. Could it hurt?
Brady
Old Apr 25, 2003 | 01:38 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I don't think it would do a whole lot except give you bragging rights that you have one.
The fuel doesn't get warmer until it gets past the fuel pump (mechanical), so it's not really warm enough for air to be able to cool it off.
If anything, the radiant heat from the radiator may actually warm it up more than it'll cool it.
A cooling can is MUCH more effective. A CAI setup would be better than that.
Old Apr 25, 2003 | 02:08 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
How cost/hp effective are the cool cans? I know that this question is relative, but...for generally speaking.
I have never seen one used on a fuel injected vehicle. Any reasons?
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
