Knock Sensor kills top end ?
Old Apr 25, 2003 | 12:51 PM
91 blue bird's Avatar
I just replaced a knock sensor and now the engine pretty much falls flat at 5500 rpms. It used to go strong to 6000rpms.
Anyone know if a K/S could cause this ?
BB
Old Apr 25, 2003 | 01:02 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I once heard that new knock sensors are very touchy...
...that's just what I heard once
Old Apr 25, 2003 | 06:37 PM
Damon's Avatar
Sure. If it's hearing knock (or THINKS it's hearing knock) then the ECM will quickly pull the spark back and power will go in the crapper.
Possible causes are REAL knock or other engine noises transmitted through the block that the ECM interprets as knock. A loose engine bracket or exhaust hitting against something can drive a knock sensor crazy.
Old Apr 25, 2003 | 10:43 PM
BOTTLEDZ28's Avatar
Transmission: A4
Did you torque it down to the factory specs. the tigher you put the more sensitive it gets.
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
gwade12
Aug 8, 2015 08:17 AM
