ticking sound
Old Apr 26, 2003 | 10:35 PM
400 SB Iroc-Z's Avatar
ticking sound
My car is making a ticking sound. It does it when i start the car and goes away after about 5 minutes. When i accelerate the noise happens more rapidly. Wondering what it is and how to fix it. THANKS
Old Apr 27, 2003 | 12:31 AM
bes217's Avatar
Oh, thats an exhaust leak for sure. You should stick your hand down there and see if you can feel an exhaust leak somewhere. If you find it just replace the gasket where it is coming out. That's how I fixed mine, but be careful not to touch the manifold or pipe because it is very hot.
Old Apr 28, 2003 | 12:05 PM
if it were an exhaust leak wouldnt it be there all the time though?
Old Apr 28, 2003 | 01:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes... I was thinking a lifter problem, but the fact that it comes back at higher rpms, I'm not sure.
Old Apr 28, 2003 | 02:09 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Sounds like an exhaust leak or maybe a rocker
Old Apr 28, 2003 | 05:48 PM
Dan88IrocZ's Avatar
High rpms only? Piston slap beeeoootch. Been there, done that
Old Apr 28, 2003 | 05:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could be the AC system too... i heard something about them ticking when they are empty.
Old Apr 30, 2003 | 09:48 PM
I dont have AC. IF it is a lifter is it a big problem and how do i fix it THANKS
Old Apr 30, 2003 | 10:41 PM
Car: 99 Formula
Axle/Gears: 342
If it is a lifter, you'll have to take the whole top part of the engine off minus the heads. And check the lifters down in the lifter valley.
If you do have too, be sure to stick a rag down in the distributor hole, last thing you want is something to fall down in there.
I would wait for some more opinions before going thru all that trouble.
Old May 1, 2003 | 01:06 AM
JAKEDPLAYA's Avatar
is it a tpi car, if so, what is the extent of the 'ticking'. I've been in a few tpi cars and all seem to have a ticking, like lifter noise is almost amplified by the tpi system or something.?.?.
Old May 1, 2003 | 09:45 AM
Car: 99 Formula
Axle/Gears: 342
He's carbed.
Old May 1, 2003 | 10:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't worry about what to do if it's a lifter, it isn't.
It's an exhaust leak at or near the head. Try a set of header gaskets; if it's been doint ig for any length of time, the gasket is toast, and just tightening the bolts won't fix it.
Old May 1, 2003 | 02:32 PM
Car: 99 Formula
Axle/Gears: 342
But why does the noise tend to go away? Then again, maybe he just can't hear it.
Old May 1, 2003 | 02:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Because the parts get hot and expand. Header gasket leaks behave like that. Exhaust manifolds act that way even more. If they're still manifolds, odds are that tightening the bolts will fix it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
