Will a 350 TPI Setup Fit a 400ci Engine
Old Jul 26, 2000 | 02:51 PM
Shawnspawn87IrocZ's Avatar
First off, will the TPI manifold bolt up to a 400ci. It yes what would I have to change to make the 400 run good. A custom chip? Bigger injectors? Higher flowing runners, manifold, and throttle body? Massive porting?
Old Jul 26, 2000 | 04:16 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Forget the stock TPI and just invest in a SuperRam not a MiniRam and 58mm Throttle Body new cam, etc, etc.....
Old Jul 26, 2000 | 04:25 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey SHAWN, it will work like you suspected, first thing to change over is an AFTER-MARKET TPI base manifold. That way, if your TPI setup came off of an 87-92 engine, you won't have to change the 4 inner intake bolt angle from 73 degree to 90 degree. Secondly, if you want it to perfrom the way it should, install some ASM or ACCELL runners with some 24# injectors and an AFPR. You will also need that custom chip and an Exhaust to allow adequate scavenging. With these components, it will make you happy but, you will upgrade again later to make it even better. Lastly, choose a cam that will work and has worked with TPI like the LPE 219/219 cam or one of SLP's EFI cams. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Jul 26, 2000 | 04:41 PM
I already have a set of SLP high flow runners, an BBK 58mm TB, and a Flowmaster Cat-back. I was thinking of going with a Edelbrock high flow runner and having the whole intake system ported to the max. I am also going to look for a set of headers that will fit the 400 and bolt up to my Cat-back system, hopefully I can find a set that won't have a clearance problem. Thanks for the help.
Old Jul 27, 2000 | 01:03 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Hey Shawn, the headers for the F-body 305-350 will physically bolt on and work on the 400 WITHOUT a problem, ALL SBC F-body emission headers will work on any 262-400 engines but, for the 400, you will want the 1-3/4" setup to help those cubes breath. Though you could install the 1-5/8" headers, the 1-3/4" is the most feasible. BTW, I have 1-3/4" x 3" SCHOENFELD long-tube headers with 3" true-daul exhaust on my 355 and they work great. Since I will be upgrading to a 383 soon, I will not have to worry about a choked exhaust system with that setup. HTH's
Frozer!!!
Jan 19, 2024 04:55 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
squiggy2
Aug 9, 2015 09:30 PM
