ticking noise
Old May 1, 2003 | 04:16 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
ticking noise
a couple days ago aftering starting my 3.1 i noticed a ticking noise coming from the drivers side somewhere. you can really hear it when giving it gas. what could this be?
ps. lately its been harder to get my car started
Old May 1, 2003 | 09:21 PM
chitown hussler's Avatar
exhaust leak ?
Old May 1, 2003 | 09:26 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i posted this before my dumb @$$ realized that there was a thing called search......
but thanks for the reply
i do have one question about an exhaust leak though
with an exhaust leak would it be normal for my car to feel sluggish?
Old May 1, 2003 | 09:38 PM
jimmy_mac's Avatar
Not from my experience and I have had many exhaust leaks.
If the tick and sluggish feeling happened at the same time you might want to investigate further. Ticking can come from your valve train. Bad lifters, studs pulling out, ect..... and if the valve train is not opening your valve correctly it could cause poor running conditions.
Old May 1, 2003 | 11:31 PM
Dan88IrocZ's Avatar
Sounds like you will be doing a V8 swap soon.
A bad thing turns into a good thing!
Old May 2, 2003 | 12:40 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hey i have a post about teh same thing in carbs and so i would go check it out
Old May 2, 2003 | 08:08 AM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
my engine is only 8 months old with a couple thousand miles on it. it still has a warranty and im not really worried about swapping to a v8 because if i was i wouldve when my piston rings blew.
valve trains and rockers? in your honest opinion what would you say leak or valves. is it possible for the ticking to be exhaust and the sluggishness to be a completely different problem?
oh yea and joc i checked out your post but mine is mpfi not carb but thanks anyway
Old May 2, 2003 | 10:32 AM
Dan88IrocZ's Avatar
So if it has a warranty, don't bother troubleshooting it yourself. Take it to the people who warrantee'd it and tell them to fix it.
Old May 2, 2003 | 11:14 AM
jimmy_mac's Avatar
Without getting burnt, hold your hand around the exhaust manifolds and y-pipe to see if you can feel the exhaust hitting your hand somwhere. Should be where the manifold bolts to the heads or where it connects to the y-pipe. It's pretty noticeable when you feel it.
But you need to figure out the sluggishness anyway. Has it been doing that since you installed it or just recently?
Old May 2, 2003 | 12:14 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Thirdgen v6's are famous for snapping the heads off the manifold bolts. I'd be willing to bet one of yours is snapped and theres your exhaust leak, hence the ticking. My v6 has one snapped, so it ticks, and I gotta give it a little gas starting in the cold.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
