What strut tower brace can I use with Accel SuperRam?
Old Jul 28, 2000 | 03:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Since I have installed the Accel SuperRam intake, I'm concerned that some or all strut toer braces (engine braces) may interfer with the intake.
Does anyone have a strut tower brace AND the Accel Superram?
TIA
'87 L98 TPI IROCZ, TF heads, 3.70 gears, LT1 cam?, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB, TB airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires, and still as slow as hell 13.82sec ET @ 106.3 mph. To be installed soon: TPIS ZZ9 cam, 2400 stall converter.
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow lid, K&N filter.
313.7Hp & 320.6ft-lbf
Old Jul 28, 2000 | 04:29 PM
David 91RS/Z28's Avatar
I have seen the Jamex brace fit over the SR intake with no problems. I have this combo but I am still working on my engine so I haven't tried to see if it will work just yet.
David Tuschhoff
1991 RS Camaro M5
A SuperRammed, TPIS,
Ross, AFR, Scat, Crane,
CompCams induced 355
coming soon!!
My f-body page!
Old Jul 28, 2000 | 05:30 PM
Tom Keliher's Avatar
The Hotchkis fits just fine over a Super Ram.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Mar 12, 2003 | 08:35 AM
85TPI400's Avatar
Anyone else have any input with this old topic?
It does not look like the BMR one will work and I am trying to see what my options are.
Thanks in advance,
Tony
Old Mar 12, 2003 | 07:31 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
RU-QWIK has a STB with his SuperRam. Not sure what brand STB though. Here is a pic: https://www.thirdgen.org/techbb2/att...postid=1173249
Old Mar 12, 2003 | 09:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
[QUOTE]Originally posted by Tom Keliher
[B]The Hotchkis fits just fine over a Super Ram.
Yea right. lol I have stock mounts and a superram and i would need to raise each side about 1/2 inch to clear the SR Once I did that my hood wont close.
Old Mar 14, 2003 | 08:24 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
I have the Jamex STB over mine. with about a 1/4" of clearance it makes the hood a real pain to open. Might try to get it closer to the SR as long as they don't rub. Of course I could put some 80 grit sandpaper on the bottom of the STB and start automatically polishing some of the SR.....
Old Mar 14, 2003 | 08:37 PM
91Z28-350's Avatar
That's a Hotchkis.
Old Mar 15, 2003 | 10:53 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
To all interested... yes, I am running a Hotchkis bar with my super ram , no clearance issues with some spacers I made. As you can see in the close up shots, I could probably even remove the spacers, but it works well now, so no need to try other things.....
Here you are.
Attached Thumbnails What strut tower brace can I use with Accel SuperRam?-00-.jpg
Old Mar 15, 2003 | 10:54 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Attached Thumbnails What strut tower brace can I use with Accel SuperRam?-0.0-.jpg
Old Mar 15, 2003 | 10:55 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Mar 15, 2003 | 10:56 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
This is the spacer... I made one for each side out of aluminum. You can see that the adjustment on the mounting brackets would most likely allow me to remove the spacers.
Old Mar 15, 2003 | 10:58 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Another ....
Attached Thumbnails What strut tower brace can I use with Accel SuperRam?-0.jpg
Old Mar 15, 2003 | 11:01 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Oh, the hood closes just fine...
Attached Thumbnails What strut tower brace can I use with Accel SuperRam?-1-.jpg
Old Mar 15, 2003 | 11:02 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Attached Thumbnails What strut tower brace can I use with Accel SuperRam?-01-.jpg
Old Mar 16, 2003 | 12:55 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Very Nice car RU-QUICK.... Are those 255 or 245 tires on your car?
I have an Edelbrock on mine, it clears just fine. The brackets for the tower to tower brace are slotted. I just had to move it up and down. Until it fit under the hood without touching the plenum under load.
I dont have any pics.. the top half of the motor is apart for some modifications right now.
Old Mar 16, 2003 | 01:23 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Thanks Mike.. The rear tires are 255/50/16 Drag Radials, the front are 245/50/16 Bridgstones...
Old Mar 17, 2003 | 04:32 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Just noticed that some of the photos's posted show no hood insulation. I guess that's where my clearance issues lie.
Do any of you recommend removing it?
Old Mar 17, 2003 | 06:08 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I removed the hood insulation only because it was starting to look like crap, not because of any clearance issues. I forgot to mention that I am running the factory engine mounts.
Old Mar 17, 2003 | 09:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Well, I started this thread a long time ago it seems.
I have an '87 IROCZ car, so with the louvered hood, I think that I will have a hood clearance problem. The car above (great looking car!) has a flat hood,, unlike my car.
So, I guess its time to break down and buy an aftermarket hood like a 2 1/2" cowl hood.
Old Mar 17, 2003 | 09:11 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
DOC. the underside of the hood is the same on both styles.... Look closely to the stamping. A factory hood will work, IROC or RS.
Old Mar 17, 2003 | 09:24 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
RU-QWIK,
do you have any problems with the engine torquing under load and hitting the brace? I know my engine moves a good 1/3" with the stock mounts when the engine is revved. It doesn't look like you have much room under there
Eric
Old Mar 17, 2003 | 10:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Man... how the he11 do you have that much room? I got spaces and its lifted all the way up and I could still go another 1/4 up. Heck the top of the TB is hitting my hood.
Old Mar 17, 2003 | 10:58 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
No, intake does not touch the bar in any spot. I have checked it with clay actually, just for the simple fact that I figure the shock from hitting would eventually hurt something, so I made sure it was 100%.
Jason
Old Apr 22, 2003 | 11:41 PM
89IRO's Avatar
Would somebody mind photo-shopping RU-Qwik's car white (the one with the STB)? ONLY if he doesn't mind-- do you mind? I am just interested seeing what that red Hotchkis STB looks with white (the color of my IROC.) Oh, I would like the picture that has the white car just to the left of it. Thanks! -89IRO
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
