why is my car waisting gas?
Old May 4, 2003 | 07:48 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i have a 89 camaro 5.0 tbi,i put on an open elment filterfrom mr gaskets and my muffler at the back was remove because it was rusted.what could be the reason that i put 5 bucks in it and i drive for like 10 min and its gonna it never waisted this much gas.what can it be ?the muffler missing or the air filter?help me out guys
Old May 4, 2003 | 10:28 AM
Vader's Avatar
Probably neither. It is more likely the installation that changed something. Make sure the IAT sensor is still connected. It may have been attached to your old air leaner.
Beyond that, you'll have to start troubleshooting from scratch. Any error codes?
Old May 4, 2003 | 12:47 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
you mean the sensor that is on the old base aircleaner that u install into the new bottom base of the open element i put it in but is not tight because the hole is bigger but its inside the base.trouble shooting for what i think its my injectors there shooting rough not smooth?
Old May 4, 2003 | 08:22 PM
Vader's Avatar
MIA305,
Well that will do it. As long as the IAT is electrically connected, an little loose fit in the air cleaner isn't a problem. Your injector spray patter, however, could be a problem. You should be able to observe a regular, cone-shaped pattern from under the injectors, with no streams or drips. A poor spray pattern can be a symptom of incorrect fuel pressure or dirty injectors.
I'd start with a fuel pressure test, then go from there. You should be reading 11-13 PSIG constantly with the pump running, regardless of load.
Old May 4, 2003 | 08:25 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
ok how do i check the pressure on my injectors?i did the code search of the ecm and i got code 44 lean exhaust what can that be? i really need my car to waste lees gas
Old May 5, 2003 | 09:23 AM
Vader's Avatar
You need to remove the fuel feed line from the throttle body and install a pressure test adapter. Many pressure test gauges come with the necessary adapter.
Old May 5, 2003 | 09:42 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
and then i reconnected it or just open the key and let it run?do i cover the end of the pressure tool or just let it run and it give me right pressure?
Old May 5, 2003 | 11:10 AM
Vader's Avatar
The adapter is a 'T' style fitting that allows fuel to flow to the TBI and provides a test fitting to attach a pressure gauge. The engine can still be operated while the pressure is tested.
1992 Trans Am
May 10, 2023 07:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
