Should the water pump be rotating clockwise or counter clockwise?
Old Jul 29, 2000 | 11:13 AM
crazeinc's Avatar
I'm confused...and if it's backwards, what would happen? I run an electric drive pump so it's a matter of which wire is ground and which one is power.
-'82 Z28 (Pro Street conversion in progress)
-'96 Grand Am (daily driver)
AIM me at: Unitedhope
ICQ me at: 77979548
Old Jul 29, 2000 | 11:22 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I think it was supposed to be as long as its on the "outside" of the belt. Or the side of the belt that doesn't have the teeth. I think if it's backwards. It won't cool your motor. And I think it might blow hoses and posible your radiator.
Chris
91 RS 305 TBI
Old Jul 29, 2000 | 11:23 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I think all eletric water pumps are suppose to turn clockwise.The only water pumps that turn counterclockwise is on a serpintine drive setup.If its turning backward then the impellers are not moving the water as it is designed to.
Superman
Rev'n to Seven
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
MoJoe
Sep 24, 2015 09:12 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
