intake question pertaining to 87' and up heads.
Old Jul 27, 2000 | 04:06 PM
nichoulas91rs's Avatar
i bought an edlebrock small block torker intake off ebay a few months ago when i was planning to drop a small block in my 83' z28. since then i bought a 454 so this intake is currently collecting dust.
i was thinking about letting my dad put it on his 92 RS. but the 4 inner intake bolts are different than stock.
heres my idea, tell me if this sounds good or not...
i fill the bolt holes on the intake with epoxy and then drill new holes through the epoxy to match the bolt holes on the heads.
i know epoxy is strong stuff but would the this hold up?
the other idea is to have the holes welded up then drill holes through the welds. but i dont know what kinda weld bonds to aluminum best.
a guy that works at a salvage yard here in town says that he just cuts the intake with a jigsaw and puts a couple of washers between the intake and the head of the bolt. he said hes built dozens of engines like this with no problems but that sounds like riggin' it to me.
oh well, i figured this would be a cool b-day gift for my dad.
92 CAMARO RS 25TH ANNIVERSARY LO3
91 CAMARO RS V6
83 CAMARO Z28 (new project!) 700r4, 3.73 posi, 4 wheel discs, 454 in the works...
Old Jul 28, 2000 | 06:24 AM
Old Jul 28, 2000 | 03:56 PM
trying this one more time...
Old Jul 28, 2000 | 04:35 PM
JP84ZROC
Guest
Posts: n/a
I was told once that you could simply elongate the afore-mentioned holes slightly by inserting a 3/8" drill bit in the hole and working it back and forth. I never had to try it so I do know for sure but it sounds reasonable if the angle is not that far off..........
[This message has been edited by JP84ZROC (edited July 28, 2000).]
Old Jul 28, 2000 | 05:19 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
you can elongate the holes, BUT!!! you can only do it on a newer (center bolt pointing up) intake manifold to put on older heads, I tried it the other way around, ran out of material to hang on to so it looked like a slot for the bolt by time I got done, it may have worked but I didnt want to chance it.
good luck
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
Old Jul 28, 2000 | 10:04 PM
Locry's Avatar
nic,
i have an 87 engine with original heads and an older manifold... they just drilled the manifold straight down and installed washers to compensate for the incorrect angle... it holds well in my engine, no oil, water or air leaks so far.
i'll be replacing it though when i get the chance just to make ultra sure...
Old Jul 29, 2000 | 09:44 AM
that sounds kinda like what the guy at the salvage yard was telling. your idea sounds better though because your drilling instead of cutting the intake with a handsaw. thanks, thats probably what ill do.
91 CAMARO RS V6
83 CAMARO Z28 (new project!) TH400, 3.73 posi, 4 wheel discs, 454 in the works...
"****'em and feed'em fish heads." daniel's building and construction.
Old Jul 29, 2000 | 10:05 AM
merf23's Avatar
I have an '87 engine with an older edelbrock performer. I had a machinest friend make 4 15 degree wedges (1/4" minimum thickness)to compensate for the angle of the center bolts. I then slotted the holes on the intake so teh bolts would fit. Its been working without any problems for 35000 miles. I saw someone do the same thing using rocker arm ***** for washers, but i liked my method better, it looks OK too.
Old Jul 29, 2000 | 12:37 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I've done it too: I just slotted it with a die grinder, then massaged it with a cylindrical rasp. No epoxy, wedges, or anything, and no vacuum leaks. I used Permatex ultra-copper spray-a-gasket on the Felpro gaskets, and it worked like a charm.
I have '88 centerbolt heads on a 1984 2-pc. block, with a non-egr Edelbrock performer intake.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
86IROC112
Aug 21, 2015 07:20 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
