how to install a B&M console ratchet shifter
Old Jul 29, 2000 | 03:18 PM
eastbayrallysport's Avatar
any ideas?
Old Jul 29, 2000 | 03:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Open the box and read the instructions?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 29, 2000 | 05:06 PM
Blade's Avatar
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Jul 29, 2000 | 05:26 PM
hookin88formula's Avatar
i have the b and m console shifter in my 88 formula and i love it just took pics of it should be back soon. it wasnt that hard to do actually. i did have to take the saw zall to the console plate but other than that it went pretty smooth other then the relay that i had to put in but if u have any other questions let me know at stahlja@hotmail.com ok..
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter
Old Jul 29, 2000 | 09:25 PM
GANGREL's Avatar
i just put mine in! its very nice i even added a 8 ball to top it off. you will { on mine that is} cut out that little bar thats in the counsel and drill 2 new holes at the top of the shifter. then you can mount it in. then the electrical is easy. the cable is a sinch. and you wont use one of them cause there are 2 in there. good luck. the best part is that you cant miss a shift from 1 2 3 then it goes into nuetral but you cant hit it in to reverse. you have to put it back in drive and lift up the handle in order to go into reverse or park. if ya got any more questions let me know later.
84 camaro 350sb 750 carb edelbrock intake 1.6 roller rockers manley severe duty valves crane fireball cam holley high volume fuel pump hp pistons stock crank mellings high volume oil pump edelbrock tes headers flowmaster 3 inch exhaust turbo 350 tranny rebuilt w/shift kit b&m deep aluminum pan msd ignition b&m rachet shifter lakewood lowercontrol arms polyurethane tranny mount {red}richmonds 4:10 gears with minispool.
Old Dec 28, 2007 | 02:31 AM
Wakelv's Avatar
Car: 85 Camaro Z28
Re: how to install a B&M console ratchet shifter
I am trying to install the Quicksilver Shifter on my car and I can not figure out which wires go where. There are four slots on the sensors but there are 6 wires on the harness. can some one help me?
Old Mar 30, 2012 | 09:40 PM
89blackbird89's Avatar
Car: 89 firebird
Engine: 2.8 soon to be built 3.4
Axle/Gears: 4th gen posi
does anyone have pics of this shifter installed?
Old Sep 22, 2012 | 02:43 PM
Haber's Avatar
Car: 1987 Pontiac Firebird
Engine: 5.7L T.P.I.
I have installed the b&m console megashfter on my 87 Firebird. Where do u mount the new light for the gear selector?
Old Oct 1, 2012 | 01:38 AM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
How Do You Install & Adjust The Cable On The Shifter?
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
TheJoeY88
Aug 13, 2015 06:51 PM
