Oil Pans
Old May 7, 2003 | 07:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Oil Pans
I am going to build a new motor for my 82 Z-28 this summer and want to replace my currently damaged oil pan. What oil pans do you guys run, which oil pans will fit? I am thinking of building a 383, will i have any interference problems with the pan?
Thanks ME Leigh
Old May 7, 2003 | 09:09 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I'm putting a Moroso pan thats made for our cars on my new 406. Part#MOR-20180. It is a 6 quart plus the filter pan and has the trap doors in it.
Old May 7, 2003 | 09:13 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
My 355 is a 98 vortec truck block, with the stock truck oil pan. It fits fine, infact, I didn't even think about fit until I realized it held an extra quart of oil, and at that time I had the engine in it ready to fire!
Old May 9, 2003 | 12:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
So truck pans actually do fit, thats contrary to everything i have heard. How about the summit pan for like $20-25, think that will fit?
Old May 9, 2003 | 01:24 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I used one from a 92 Caprice. The only diff from a Fbody pan is the hole for the low oil level sensor, which I plugged. The year of the block makes a difference on which oil pan you get. 80 & earlier take one type, 81-85 has the dipstick on the pass side & 86 & up has the one piece rear main. Most any standard pan will fit on the 3rd Gen chassis.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
