Won't Pull Past 5000rpm
Old May 11, 2003 | 10:25 PM
88_RS_2.8's Avatar
Hey all, a friend of mine has a '84 Z28 w/ a L69 305, and a T5. Now, before the car would pull smooth to redline, now, it pulls nie to about 5000 then, it just wont pull, we have replaced the exhaust and the fuel pump w/ no change. If anyone can enlighten me of this situation that would be great. Thanks in advance.
Paul
Old May 11, 2003 | 10:27 PM
Momar's Avatar
When the exhaust was replaced did you change the catylitic converter?
Ben
Old May 11, 2003 | 10:29 PM
88_RS_2.8's Avatar
No we didnt change the cat, do u think that could be the problem? I was thinking that it might be the ignition module. And Thank You for the quick reply
Old May 11, 2003 | 10:32 PM
Momar's Avatar
I dont really know what all could cause it. I know that when a cat converter goes bad it can cause a great loss of power in the higher rpms. I dont know what all problems the ignition module can cause, but I know that when mine went out the car just stoped working. I think I have heard of them causing problems with high rpms, but am not sure. I would think that it would cause a problem before 5000 though.
Ben
Old May 11, 2003 | 10:45 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
when was the last tune up?
plugs, wires, filters, etc.
if it has a stock cam there is not too much more power left up there. ( 5000+)
Old May 11, 2003 | 10:52 PM
88_RS_2.8's Avatar
The last Tune-up was Febuary 7. It has a mild cam, but nothing radical, just barely over stock. If anyone has ideas, they will greatly appreciated. And thanks to everyone that has replyed.
Old May 11, 2003 | 10:56 PM
88_RS_2.8's Avatar
Follow Up:
The cat was gutted, i just talked to the owner of the car, any ideas?
Old May 12, 2003 | 12:10 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Junk the cat if you don't have to pass emitions. Its like a brick wall on a revv-happy engine like that L69.
Probably needs a tuneup too.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
kyle5647
Aug 7, 2015 03:08 PM
