Hypertech chip intall
Old Jul 31, 2000 | 02:42 PM
87formula350JJS's Avatar
I just bought a chip on ebay and am wondering if there is any thing I should know before I install it? I know for sure that it is for my year and model car. But other than that any other intall procedures or tips would be greatful. thanks
flowmaster,afpr,coolant by-pass,ex.cutout,ported plenum,hyp.chip,cold air intake,airfoil,mod.maf
160 thermostat,hyp tech fan switch, B&M shift Kit,
Old Jul 31, 2000 | 03:28 PM
and also the chip is a hypertech thermomaster stage II If you have one are yah happy with it? Thanks
Old Jul 31, 2000 | 07:03 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I liked my thermomaster. U have to get a 160* stat with it though. Keeps your engine nice and cool. 5-10hp i would guess.
Eric Natzke
91 Firebird 305 TBI (dropping in a 355 summer of "01")
Edelbrock TES Headers, P265/50/R15's, MSD 8.5mm superconducters,TBI Spacer,Accel Cap & rotor,180 Fan Switch,160 Thermostat,Hypertech Thermomaster,TransGo ShiftKit,B&M Supercooler, March pulleys,Dynomax 3" Cat-Back w/ flowmaster muffler,Smog pump and AIR pulled, Edelbrock Strut Tower Brace, 3:73 Richmond Gears and K&N 14x3 open element.
http://hometown.aol.com/J007Golden/index2.html
Old Jul 31, 2000 | 07:09 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I have the same chip, I love it. I may be getting rid of it though, because it is not good to run a chip like that with ntrous. Ths install is VERY easy, I did mine in less than 10 min.
1992 Z28 5.7 TPI 700R-4
Old Jul 31, 2000 | 07:57 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i didnt care for my hypertech chip (street runner) at all, not really any gains.. anyway the install is easy as cake..
under the pass side dash is the computer, youll see two wiring harnesses going into it, unplug them both (squeeze tabs, and gently pull), then there are two 7mm (i think) screws holding the ecm into place.. once it drops down, youll have it in your hands (at this point make sure you are either in constant contact with the body of your car, or some sort of ground because ecms are extremely sensitive to static.. youll see a rectangular cover with two (i forget what size) screws holding it on, take that cover off and youll see the chip, gently remove it (use a puller, or a small flat screwdriver to gently and evenly lift it up.. the new chip should only go in one way, just make sure the notch in the carrier faces the same way as the old one.. then reverse the procedure to put it back together..
Old Jul 31, 2000 | 10:26 PM
Tom Keliher's Avatar
Go to Radio Shack, and buy a "wrist ground strap". Use it when changing proms, to avoid static discharge damaging your chips.
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
