Need Help..!!!
Old May 14, 2003 | 12:11 AM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
Need Help..!!!
i finally have my own there are a few problems that i have no idea how to fix. I have a 1988 RS The problem is that the steering wheel moves to much it moves side to side and im not sure what is causing this if you can help please post or PM me.
Old May 14, 2003 | 01:07 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You may want to try the suspension board. You'll get more responses, as well as better ones.
There are a couple things that can cause a loose steering wheel.
The steering box. The gears wear out just like anything else.
The pitman arm. It's what transferes the movement from the box to the tie rods.
The tie rod end links. The stock ones are nothing more than sheet metal wrapped around the tie rods and ends, with nothing more than clamps holding them.
The ball joints. They're what hold the tie rod ends to the steering knuckle.
The control arm bushings. They're what attaches the lower "A" frame to the subframe. They're soft rubber and will harden enough to cause them to stay contracted instead of expanding enough to fill the hole they're in.
Last, but not least, is the wheel bearings. I'd hate to think they're loose enough to cause a noticable difference, but it's happened.
That's all I can think of off the top of my head.
As I said, try the suspension board.
Old May 14, 2003 | 07:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Good list.... I might add, the center link, which is the piece that goes between the tie rods and hooks to the steering gear; the rag joint, that connects the steering wheel to the steering gear; and the "frame" cracked around the steering box bolts.
Old May 14, 2003 | 01:53 PM
AJ_92RS's Avatar
We both missed the most simple one...
Not enough air in the tires. That can give a real loose feeling.
Also, the lug nuts could be loose. Hopefully you'd notice OTHER things like the shimmy shimmy cocoa puff coming through the wheel.
Mshrmhd
Feb 27, 2003 10:57 PM
BOTLFED
Jan 31, 2003 02:57 PM
Kj Rockz
Jan 18, 2003 05:33 AM
telstar
Jul 15, 2001 11:11 PM
83_TA
Jun 21, 2001 07:13 AM
