zz-3 cam?
Old Jul 31, 2000 | 06:53 PM
5LtrEtr's Avatar
zz-3 cam?
I am thinking about buying a used zz-3 with about 5,ooo miles on it for my 91 Z28 with a 350Tpi and automatic tranny. All i have for mods is pulleys, afpr, jet stage 2 chip, airfoil, k&n's, tb coolant bypass, homemade ram air and ported plenum and lower intake. Wondering what your'e ideas are on buying it used and what kind of hp gains can I expect, or any experiences you have had with this cam. Thanks.
Old Jul 31, 2000 | 07:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have that cam in my car. However you will need to change the springs on your heads, as they wont handle the high lift of that cam. I used Manley springs.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old Jul 31, 2000 | 08:45 PM
5LtrEtr's Avatar
Anybody know how much hp this cam is worth? I will be installing 1.6 Harland Sharps roller tip rockers also.
Old Jul 31, 2000 | 09:56 PM
5LtrEtr's Avatar
ttt
Old Jul 31, 2000 | 10:28 PM
LSTUD's Avatar
You might want to go with 1.5 ratios on the exhaust side. I have a zz9 cam and it ideled
like sh** with 1.6 on intake and exhaust. It is still real lopey I may put 1.5 rollers on both. zz9 is simular to zz3 pulls hard to 5000.
87IROC Z28
355 5-SPEED,HEADERS,ZZ9 CAM, RAM-AIR, K+N FILT, PORTED PLEN, MOD MAF, T/B BYPASS, 1.6 ROLL ROCK, TRUE DOUBLE ROLLER TIMING CHN, JET CHIP, AIRTUBES-CAT-SMOGPUMP-GONE, 95 10-BOLT/3.23, ALUM DRIVESHAFT, ACCEL 300 IGN, RELOCATED MAT.
Old Aug 1, 2000 | 12:23 AM
Kevin91Z's Avatar
According to Desktop Dyno 2000 its worth 25 HP over stock. Your mileage will vary.
I have 1.6 rollers on the intake and 1.5 rollers on the exhaust, too.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
