Motor Mount replacement
Old Jul 28, 2000 | 08:32 PM
valu8or's Avatar
I am trying to change the motor mounts before I install a new motor. How do you get the motor mount bolts out? The nuts are located in the frame and are very difficult to get to. All suggestions are welcome.
Old Jul 29, 2000 | 07:17 AM
ede's Avatar
ede
there isn't an easy way. some people have said they've heated and bent a wrench to get the right angle on the nuts. last time i did it i torched off the bolts and welded the lower mount in like they were on first gens and dozens of other cars. i know lot of people would say i butchered my car doing it, but it's my car.
ICON Motorsports
Old Jul 30, 2000 | 10:16 AM
valu8or's Avatar
Old Jul 30, 2000 | 11:28 AM
Steve89Formula's Avatar
I was actually able to replace BOTH of mine BY MYSELF when installing my rebuilt motor. I posted on how I did it a few months ago so if you search you may still find it. The jist of it is, find as many different sizes and shapes of (I believe) 14mm wrenches as you can. A long skinny one is a good one. There is a round hole in the sub frame about 1"-1.5" in diameter. You can use it to get the wrench in at a decent angle. PATIENCE! Not something you can just do quickly. Have a magnetic pickup handy for when the nuts fall into the subframe.
If I have some more time I'll try to find my original post. (Something crazy like "Secrets of Motor Mounts Revealed.")
Old Jul 31, 2000 | 12:47 PM
valu8or's Avatar
I looked for the old post and did not find anything. Has anyone ever removed the lower a-frame to do this and how hard was that? It looks like that would be the easiest way to change the motor mounts. If I have this off should I replace the front springs? Just wondering.
Old Jul 31, 2000 | 12:58 PM
Scott C's Avatar
I am in the same boat. I would like to change the mounts before I install my new 350. I was thinking about jacking the car up as high as possible to lower the a-arms for more room to get to the nuts. I plan on trying this today, so I'll let you know what I find.
Old Jul 31, 2000 | 03:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Drop the A-arms and the nuts will be staring at you.
Sounds like a lot of work, but the extra work of taking the A-arms down makes the even more extra work with bent wrenches, skinned knuckles, etc., a good trade. No butchering, either.
Replace springs, balljoints, bushings while you're at it. Wow, 4 birds with one stone!
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '90 305HO, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress.
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Aug 1, 2000 | 10:34 AM
JunkHead84's Avatar
did anybody get it to work???
Old Aug 1, 2000 | 01:31 PM
Mike 25th's Avatar
I am in the middle of a header install and decided I was going to change the motor mounts at the same time. That is until I saw the bolts on the back... You think GM could have welded the nuts to the subframe... My car has only 50,000 on it so I'll kepp the motor mounts I have for now. When I get ready to lower the car, I'll do the mounts while the front end is apart...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
69 Firebird - Chevy 327 - Black/Black - SOLD 7/4/00
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Elliswon
Aug 10, 2015 12:33 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
