Which oil pump???? Please... I would like to order this in 30 min! thanx!!!
Old Aug 1, 2000 | 12:28 PM
Slick50's Avatar
this is for my 350. my 305-350 conversion.
I really need to know what oilpump exactly. I have a summit and Jegs... so if you can actually give me a great recommendation I'd apprecite it
thanx
oh yeah... I hear highvolume is not good... give me your 2 cents on that too
thanx
Old Aug 1, 2000 | 12:38 PM
zguy2882's Avatar
I'm sure this will get some discussion but personally I would stick with a stock replacement pump. Just make sure you get a quality one like Sealed Power, Melling, etc. Sometimes high-vol. and/or high press. pumps can be more trouble than they're worth.
Old Aug 1, 2000 | 12:43 PM
FastBroker's Avatar
I agree. Get a Melling standard ($20) and you'll be fine. You only need HV if you are seriously racing w/thinner oil or you have worn motor w/bearing clearances of one inch (haha)
Old Aug 1, 2000 | 12:45 PM
Slick50's Avatar
D'oh... in summit all of them say high-volume oil pump!!!! What do I do?...
Old Aug 1, 2000 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go to Auto Zone and get a M55 (about $11 or $12) and a 55S screen, and order a Mr. Gasket high-pressure spring from Summit ($4 or $5). Use an IS-55E drive rod.
Old Aug 1, 2000 | 01:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Curious- what about all that jazz about welding the pickup to the pump.. is that needed? I find it hard to believe that something so important as an oil pump would be made with a weak joint...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Aug 1, 2000 | 01:38 PM
Guest
Guest
Posts: n/a
Excuse me, but Chevy has the absolute WORST pickup design known to man. I have heard of pickups falling off the pump, or actually out of as it may be. My 65 Mustang, and any other Ford I have worked on, has a bolted on pickup. The Chevy one is a press fit (read:hammered) into the base of the pump. Blech.
Oh and BTW, I am positive Summit sells the standard pumps too, just ask. The Melling part number is what RB listed, M55. (just a FYI, the Sealed Power pump is... melling )
[This message has been edited by madmax (edited August 01, 2000).]
Old Aug 1, 2000 | 02:48 PM
ede's Avatar
ede
i use a melling m55 and weld a brace to the pick up and bolt it to the pump body. i would never weld the pick up to the pump, to easy to distort something.
ICON Motorsports
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
