383 questions
Old May 17, 2003 | 06:02 PM
89 RS vortec 35's Avatar
383 questions
I was considering buying a 383 stroker kit. My question is how much horsepower will a Scat 9000 series nodular crank handle? I know that forged is better but this won't be handling amything over 550hp, probably not even that much. Also, what kinds of heads would work good on a 383 that aren't extremely expensive?
For those looking for forged cranks and rods, Flatlander Racing sells Scat cranks and rods fairly cheap. www.flatlanderracing.com
Thanks for the advice!!
Old May 17, 2003 | 08:02 PM
ede's Avatar
ede
you can find a lot better parts than scat, even if you don't make a lot of power. more to what kind of power, or abuse, a part can handle than the part it's self, machine work also comes into play as does how straight, flat, round ,etc. the parts are.
Old May 18, 2003 | 07:40 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The Scat cranks are not that bad.The owner of shop that built my short block is a die hard Callies man at first he didnt even want to build my engine because I was going to use a Scat crank and rods but he did.After he looked looked at and balanced every thing he said that the parts were not bad and everything balanced easily.Also there good to 600HP and 6500RPM
Old May 18, 2003 | 07:49 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hmmm
be sure to check for burrs....... flatlander is paying to have my crank turned and send me new bearings for scats ****ty deburring...
not even 100 miles
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
