Oil Pressure Gauge Drops to 0 !!??
Hey there, new guy to the boards here. Just bought my first 3rd gen last summer, and I love it. Sounds like you guys really know what's goin' with these cars, so I gotta question for ya'll. My ride......
86 TransAm
305 TPI Automatic
187,XXX miles
All Original except the paint (that I know of)
I just noticed today that my oil gauge drops to 0 when I go around a corner or pull up to a stop. As soon as the car is straight again or idles for a sec. when I stop, the gauge jumps back right to the middle. I never noticed it before today. Anybody know what's going on???
Thanx a lot,
Neil
86 TransAm
305 TPI Automatic
187,XXX miles
Thanx a lot,
Neil
Car: 4
Engine: 6
Transmission: 5
Yup, start there.
If the level is at "full" and it still does it, try adding another quart. If that fixes it (or at least greatly improves it) then the pickup has probably fallen off of the oil pump, and the hole in the side of the pump is probably getting uncovered when the oil all sloshes away from it.
There's no cure for that other than pulling the pan and fixing it.
Car: 1991 Firebird
Engine: 383 stroker
RB83L69 is probably right. I had that happen to me TWICE. I just wish that I would fixed it right the first time. The second time I had to do it with the engine in the car. Not fun.
Tom
Tom
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
my car does that too...but I havent fixed it...Im sure thats what the problem is ...
Car: 04 Vette
I had a cavvy z24 that did the same thing I new the pickup had fallen off but I kept driving it that way till one day the rod decided it had had enough and broke in two drove it home though rod just broke didn`t make any exit wounds.
wow
Hey thats some great info there! My dads engine just started havin the same symptoms as TGVirgins car has. Since the pickup is only pressed into the pump, im sure thats what it is. Thanks!
Jay
Jay
Easy Fix
Wow, all that info is good to know. So I just checked the oil level just to make sure. I thought for sure it was good, but apparently it hasn't been looked at for a while
. The level didn't even register
. Some new high-mileage fluids, and problem is solved. Thanks for the help though!
Neil
. Some new high-mileage fluids, and problem is solved. Thanks for the help though!Neil
ambainb
Apr 25, 2016 09:21 PM
